Followers 0
Cranky Dog
Translucent bones. A problem or an opportunity?
80 posts in this topic
Only one point I do not like, it is the red translucent fire. Mostly because I see so often yellow drybrushed fires. Fire painted from the inside out.
That was my first thought when I got the red elemental minis. I would have preferred yellow, or at least a "fiery orange" rather than the deep/dark red that I got here. However, I've gotten fairly decent results by painting white-yellow-orange in the /recesses/ of the fiery figures, and then leaving the edges red. Sure, everywhere I paint in the deep areas won't be TRANSLUCENT, but it still seems to work nicely enough on the table. The deeper red therefore ends up at the extremities of the figure, where the plastic tends to thin out a bit (for greater translucence), giving the figure something of a "soft" edge that I think contributes nicely to communicating that it's a non-solid entity, even if the core of the figure is bright and opaque. (The effect seems to capture better in person, rather than in a photo, though.)
Example: Large Fire Elemental:
2013-07-06-reaper-bones-77082-fire-eleme
4 people like this
Jordan Peacock, that's the sort of effect I want when I start painting the elementals.
About baking soda bases, would varnish help protect from yellowing? I've only done a couple of snow bases using soda and they're still white after several years. I tend to finish off my bases before spraying them so that the varnish helps to hold the flock, sand, soda, whatever on.
I am not a fan of the translucent figures I got in my first Bones kickstarter. It makes them look too much like toys instead of figures I can paint to a high standard. If I paint over them, I feel like I wasting the translucent effect.
Plus the wings of the Elemental girl were super-thin
I'd rather buy them in regular white plastic.
--Chris
www.chrisvalera.com
Anywhere from 8 months to Never. The problem is that baking soda is a base, and chemically reactive. How fast it changes color, if at all, depends on what is in the air. It's a roll of the dice.
And dice hate me.
I've seen it argued that it's not so much the baking soda as the glue used that causes the yellowing.
Overall inconclusive for now.
I can confirm it's the baking soda. Remember, people put it in their fridge because it absorbs odors. This means it also absorbs other contaminants. To what extent it will turn will depend on the environment and whether or not it is covered (i.e. used as ground cover in a display case).
For example - if you live in a low dust, low pollutant, low humdity environment and it is covered - may stay white for a long time.
But if you live in average+ humidity, it is uncovered, and you smoke? It'll be shoe leather brown in a month or two.
Thanks for the info Buglips. ::):
Personally, I use Woodland Scenics "Soft Flake Snow." It works great with cyanoacrylate superglue for thick blankets of snow, or with craft glue for thin ground cover.
2 people like this
Second this. I think (you might want to look this up first) that you can also mix it white white glue and make a "paste" you can use to sculpt snowdrifts. But I'm not 100% sure on that, because that comes from my dabbling in other hobby forums and I don't spend as much time with the railroaders and armor people as I do here.
Has anyone thought of/tried inserting a small led into the base of one these translucent minis yet?
Edited by Bloodhowl
People have mentioned it, and someone might have even tried it, but I haven't seen much in the way of photos/video of someone having done it.
I thought about it, then decided I would need to learn basing skills first.
I have, but I need to build the base that is going to hold the LED set up. I am using a cheap LED 'tealight candle' for a jack-o-lantern with the big fire elemental
2 people like this
That's how I like it. :-)
I love translucent miniatures,
That is all.
1 person likes this
I have to say, I am pretty impressed with the photos I have seen. There are some mighty fine paintjobs on these translucent minis. Mine however, look awful, and I think I am going to have to "pine-soak" them all.
I found the glow in the dark craft paint needed a lot .. A LOT.. of thin layers to be really effective.. but it still wasn't all that bright
I did not use a lot of layers - but I also spritzed with The Army Painter matte sealer first, then an ink wash, then the GitD paint - so there was more to it to cling to.I did not try to drybrush straight onto the Bones.
That, I was going for a very pale luminescence without losing the translucence of the figure.
I have not yet tried it on the, umm... ghost chick thingum....
The Auld Grump
Edited by TheAuldGrump
Followers 0
    • By Lidless Eye
      Another set complete!  This time it's a group of Eastern Fantasy themed adventurers and encounters.  Almost all the minis are from the third Bones Kickstarter, with the exception of the Tengu/Kenku Monk armed with kamas.  She's from Stonehaven.
      The group:
      The Oni:
      The Kitsune.  The male is one of my favorites...I hadn't even noticed the sake glass in his hand  until I started painting!  That and his swagger make for a very characterful sculpt.
      Just some Human Monks:
      The Kenku/Tengu:
      This is the non-Reaper one, a Monk from Stonehaven Miniatures:
      Flock!
    • By TGP
      @Everyone :: Please feel free to share pix of creations from the Conversion Classes in this thread.
      I will **start:
      As a beginning exercise Gene Bobby and Jason had everyone pick a body, add one thing, and pass it to the right. That was repeated three times. These were the result.
      **Be warned I have moar pix...
    • By Guildenstern
      Idk if this is a KS model or one I randomly bought to fill out our need for giant monsters that are not cardboard cutouts. Anyway, he's done. He was going to maybe go in a desert diorama but I decided against (he didn't end up fitting). I might go back over his claw bits again tho, they seem a lot darker in the pic than they do IRL but theyr'e still just not quite right. Anyway, he's based on a couple of RL pics, mostly going for a shiny red carapace kind of idea. He's not in my WIP thread, so just a quick note, I undercoated him mournfang brown (a red brown GW colour) and then built up to the red with reaper's bloodstain red and later clotted red (my absolutely fave triad *ever*)
    • By Lidless Eye
      Another batch of deadly forest encounters, the kind you'd find protecting Castle Stoneskull!
      All miniatures are from the Castle Stoneskull set from Bones III.
      Vegepygmies:
      Plant Dragon:
      Death Lilies or something like that!
    • By rollcast
      I'm just really proud of this, my first work with an airbrush ever. Maybe it's not the best skill & craft work out there for finishing a figure, but I think I win some points for originality.
      What I learned...
      Sometimes, inspiration comes when you think your finished (my son said "I thought you were going for a nebula") Sometimes, your wife says "It needs something iridescent" when you think you're done and she's right. Sparkling Amethyst on the spines Airbrushing means mixing and getting your consistency exactly right - I got lucky on my first try Airbrushing base colors is insanely fast, uses almost no paint and produces something much more even than I could dry-brushing Dry brushing is great for aging/leathering a piece - airbrushing is all about consistency of coverage. Trying to add red-shifted & blue-shifted stars to the star field looked like birthday cake sprinkles. Nature always has better color schemes than I can come up with on my own. I still need to figure out how to layer/thin/build up my colors.
      After initial airbrushing with Violet Shadow and Clear Magenta and maybe a mix with aged bonne for the belly.
      First pass at layering for the spikes. I've got some learning to do.
      Another angle at the "ready for detailing" stage.
      My son said "nebula" and I broke out the clear blue and thinned it, but probably not enough.
      Here's the "finished" product. I detailed so many stars in the blue areas. Then my wife said "iridescent" and I added Sparkling Amethyst to the spines. It's a great touch and highlights the raised part of the body instead of leaving it the same as the rest.
      For scale against another recent work, my lizardman army.
  • Who's Online   43 Members, 3 Anonymous, 0 Guests (See full list)
