Questions (and maybe WIP) re flat/2D terrain building "fronts"
So I'm thinking of building terrain "fronts" by taking some leftover foamcore, some photos of buildings, and creating some fold-out support  ('L-shaped?) so that they will stand up.
Has anyone ever tried this?
I'm thinking of building fronts because
a) more easily stored
b) give me lots of flexibility to create mood
c) my GNL mats will be used for layouts.
d) faster than building full, playable bulidings
I'm wondering about sizing. if I do 12 ft per story, that'll fit on an 8x11 paper? I suppose I should compare it to my existing 2 floor MDF stuff, but different eras.
I still have no idea yet whether I can find enough photos at sufficient resolution to do this.
I took one from google streetview (spoilered), which is also  3 storeys. I suppose I will test something out and report back.
In the meantime, please make suggestions, refer to other similar projects/products you're aware of.
Edited by lexomatic
There are several types of terrain in the "fold flat" method that you can just print out the "front" and a couple inches back on each "side" to end up with a "U-shaped" piece that should stand up pretty well.  If not, add a bottom and some removable weights to it.
Fat Dragon Games (some free if you pledged on the latest KS) has some nice buildings in PDF format that the PDF has layers so you can change the doors, windows, vines, etc... so you end up with multiple similar, yet different, buildings.
Part of the problem, is the game in question is set in a particular location, present day, so I need some recognizable landmarks. I can't use generic fantasy type stuff. For some buildings, maybe, but not all. I think any skyscrapers could be totally generic.
Sadly none of the stuff that comes in the KS PDF thank yous works for this setting.
Fat Dragon hasmodern buildings in their Capital City set. I have been happy with the set and they should give you some flexibility.
It sounds do-able.
What you're describing (L-shaped constructions with one side folded back for support) sounds like it would basically be a little "Potempkin Village" full of Hollywood special effect style facades, and if so, it's certainly a lot simpler than building complete papercraft buildings and so on.  As long as you're OK with the lack of depth, your main problem would probably end up being stability: the facades would catch every breath you exhale near them like sails!  You might get more mileage from the U-shape suggested by someone else above, or by giving the buildings four sides for an O-shape that can be collapsed and stored easily.  You might also find it useful to paint a wide, short cardboard box black, and paste three or four foamcore building facades onto the side of the box (if you work in an office, you might find that the lids of the cardboard boxes that printer paper ships in would work well for this purpose, or perhaps even the boxes themselves); building a block of buildings like this would provide them with the stability of the box they are pasted onto, and keep them from getting easily knocked over or pushed around.
If you go with 10' per storey, you might be able to get as many as 5 storeys on a standard 8.5x11 sheet of paper printed in portrait format, or four storeys if printed in landscape format (assuming a scale of 1"=5').  10' storeys (or less) should probably be just fine if you're just building facades - it might not technically be the right scale, but it's not like you have to make any special headroom for the minis or leave room for floors and ceilings and the spaces between and so on, so I'm pretty sure nobody will notice without taking out the slide rule and measuring carefully.  :)
    • By lexomatic
      Some friends are doing this, under their Infinite Dimensions Games, though I'm not involved. The Kickstarter will take place in March and is for digital files for 3D print. If I remember correctly there are no physical rewards. While people should hold off until the details of the crowdfund are released, my understanding is that the core set is done, any stretch goals will pay for the labour of doing the design/sculpting of those items only, so the core set would be ready as soon as funding period is over.
      They have a Facebook and Instagram and more for lots of previews (but I'm not linking because I'm not sure what on those sites will break forum rules), and if anyone is attending BreakoutCon this year in Toronto, they will be there displaying.
    • By SamuraiJack
      Create mystic landscapes with our Sacred Sites range of scenic resin models for gamers.
    • By SamuraiJack
      CAD designed precision laser cut MDF buildings at 28mm 1/56th scale. Ideal for WW2 tabletop wargames like Bolt action etc.
    • By SamuraiJack
      TIME WARP featuring Rampage Castle and detailed game-ready buildings from Europe and the Americas designed for your home 3D Printer
    • By Pingo
      My birthday is imminent (precioussss), and my husband gave me this resin ship model from German manufacturer Gelaendestuecke.
      I've never done anything like this before: Never worked with resin, never made a ship model, never tried to figure out rigging and sails (they aren't included in the model and even the masts are just dowels at the moment).
      So ... Woohoo, I have no idea what I'm doing. But I figure it'll be fun figuring it out.
      Here's the box
      And the instructions in their entirety
      The hull and the deck
      The wooden bits, the mast, bowsprit, and railings
      The cabin has a few issues. Note the little spot the arrow points to. That becomes relevant later.
      It also has a big missing spot from a bubble in the back
      And a crack and missing piece on one side
      Okay, so here's how I've begun it.
      First I scrubbed the resin pieces with a toothbrush in very hot water and dish liquid. There was a nasty waxy substance under the hull which I assume is mold release.
      Once cleaned, the bottoms of the pieces were really shiny, which seemed like it would cause a problem with the epoxy adhering.
      But sanding resin is problematic. Its dust is very fine and lightweight and highly toxic. Bad stuff to breathe.
      So I sanded them underwater, with a few drops of dish liquid add to break the surface tension so the dust wouldn't float on the water. Resin really wants to float.
      Sanding on the cabin exposed a greasy, waxy white substance where that little splodge was, something like a white oil pastel, and kind of gross.
      Scraping it out exposed more of it within the resin and lost a few flakes of the surface. It can be seen, rather big in this picture of the ship as it is at present.
      And here's a side view.
  • Who's Online   53 Members, 2 Anonymous, 0 Guests (See full list)
