Received a message from Pegasus Hobbies that the Power Plant and the two Platformer kits are out of production, and there has been no contact with the Russian company that produces them.  Also I am waiting for a response as to how many Chemical Plants are left.
Boo...
Even a klutz like me can see the value in those kits (especially if Prodos ever get their act together regarding the AvP wargame).
Okay, here are some pictures of what has been completed so far.  I have chosen to use glue in several places, Testor's Plastic Glue, for strength.  It dries quite fast with this plastic.
The first two pictures are something I designed and the second two are a basic design from the instructions with a modification, adding the down pipe in the tower.  As you can see with the two assembled structures there is quite a bit left over so I will add them to the second and third kits and see how big I can increase the plant size.  The two structures can be added together and to the next assembly.  Pegasus Hobbies indicates they have quite a few of these kits, sooooo I think I might purchase a few more just in case I want a rather large Chemical Plant.  There are many pieces but once the parts are removed from the trees and cleaned of any excess plastic then it gets addicting/fun in the assembly mode.  I think I will use one of the base boards I use for the mountains, for the Chemical Plant.
  • Like 11
Some more progress, still working on parts from the first kit.   I am building modules then putting them together.  Eventually I will need to prepare the base board as it will become too large to transfer from the work/gaming table to the base board.
In the close-ups you can see pipe runs to connect to future modules, and connectors on the sides of the tanks.
  • Like 9
I started on the next two kits to attempt to duplicate the plant in picture 31 of the instructions.  It is not going to be easy with so much hidden in the picture.  I have, I think, identified most of the major components.  So I think I will try a front to back type of assembly.  To fill out one of my mountain bases with a Chem Plant, I will need more kits... so I ordered five more!!!  If this gets as big as I think it might, I will need to anchor it to the base panel.  Not quite sure how, as yet.
  • Like 11
Here is the base board covered with, I think, a copy of a Star Fleet Battles miniatures game sheet.  I am not sure who produced it and I am quite sure after 30 years it is no longer in production.  I probably should try to have it printed on something heavier if I do another, as the paper started stretching while I was gluing it down.  So as you can see, you can get an idea of how much area I plan to cover, and how high it is... so far.  Pictures are with Camera flash and Fluorescent light.
  • Like 11
Sometimes things can be in plain sight. The front and back box pictures show various angles of picture 31 that I am working on.  The one part I cannot reproduce is the Platformer Kit platforms shown on the back.
  • Like 9
Construction continues with a second box. As usual pictures are with and without camera flash bulb.  Some 600 parts here, then more parts and some basic assembly.  Next some major assembly started.  I had to stop for a moment and draw out the plan from the picture.  It took a bit for the front half trying to figure out the base supports, which works out ,so far, as the two stands in the lower left of pictures three and four.  I still need to draw out the back half plan.  As is evident from previous pictures, the box shows two different plants.  I am working on the black and white checkerboard plant.  Last picture... yes that is five more plant kits for a total of eight... well that is a big base board I want to cover.
Edited by Watchman
Correction
  • Like 11
Continuing progress figuring out the internal structure.  Not perfect as it appears there may be a few parts from the Platformer kit, but this is what I have come up with to date.  Also other components completed so far.
  • Like 8
Progressing in identifying the internal structure.  Opened the third box, that is 900 parts to deal with.
  • Like 9
Continuing on, here are some internal shots of what I have been able to figure out from the box photos for those daring enough to purchase one... two... many of these.
Current progress.  I find, depending upon the configuration you use, there is a shortage of pipe adapters.  If you end up in a situation where two pipes meet up face to face, then an adapter is needed.  My two solutions are: remove the flange from a pipe section to make an adapter, or glue the sections together which is what I am in the process of accomplishing in the second photo.
  • Like 10
    • By Lidless Eye
      Another batch of rotters, fresh off the assembly line!  The forces of the Brothers of Rust get more...rank!  (Badum tish)
      Converted Biologus Putrifiers:
      Also converted, a set of Foul Blightspawn:
      Icon Bearers:
      Blight Launchers:
    • By Arc 724
      Primaris Space Marine (Warhammer 40,000)
      by Games Workshop
      This was my first warhammer figure I've ever done. I've always enjoyed the theme of the game but never really like the Space Marines because they are to short. When I saw these new, taller, ones I actually got excited to paint one. The height on these guys are amazing. They really have a better feel about them. The issue was that I only wanted to paint one (for now) and that is when a friendly forumnite told me about this book they just released "Getting Started with Warhammer 40,000." I jumped at the chance at the book comes with one miniature on a nice base for only $15. I called my local GW store and they saved it for me. I would highly recommend this to anyone looking to just paint a miniature and not spend loads of cash on a single miniature or a three pack.
      I decided to go with a blood angel look for this guy. But I wanted to make it look a little unique so I did those grey chevrons on the shoulder and knee. This was also the first time I've done battle damage like you see here. It was FAR easier than I thought and the look is wonderful! I was very happy the way it turned out.
      With this guy I did fill in the base with GreenStuff to give the model a little bit more weight. You can see that in the WIP below.
      Thanks for the support.
      WORK-N-PROGRESS for this piece.
    • By Lidless Eye
      Let's get Nurgly, Nurgly!
      Here's the latest reinforcements for the Brotherhood of Rust, devout followers of Grandfather Nurgle.
      The (un)Holy Accountant, the Tallyman!
      "This my Power Abacus!"
      Those dread bodyguards, high in price in both points and dollars, the Deathshroud Terminators!
      The rustiest of them all, the Blightlord Terminators:
      The grunts of any Death Guard force, the ever-versatile and never dying Plague Marines!
    • By kristof65
      It's been 6 years since I last played a sci-fi table top game in 28mm.  Wondering what is out there BESIDES 40k these days? What are you playing and/or what do you recommend?
      My favorite in the past were 40k 2e and Necromunda.  I prefer more skirmish level, and capable of handling multiple players/sides.
    • By Lidless Eye
      My last-minute WiP entry for the Iron Sleet Invitational (https://ironsleet.com/2017/10/24/invitational-firing-on-all-cylinders/)
      THE HERESY OF CALLAHN 7
      How many years had it been since the rebellion first began on Callahan 7? For unknown decades, traitorous PDF forces lay siege to the palace of their former leader, a vile governor who thought of little but profits and nothing for safety. His shortcuts lead to a doomed populace; the atmosphere poisoned and its people dying by the acid mines and foundries that the planet was known for.
      The rebellion stayed at a stalemate for years, with the superior numbers of the turncoat PDF unable to overcome the superior armory of the few that stayed loyal to the governor. Even once the rebels opened the acid mines and foundries, and freed the twisted and broken mutants that manned the world beneath, the palace remained sealed.
      Then, the Brothers of Rust came. Their grand fleet looming overhead, the few Heretic Astartes who touched planetside turned the tide of the battle in scant days. The governor's palace fell; he and his servants bodies strung from the walls, the first of many sacrifices to the Dark Powers.
      Many of the PDF went with the Brothers, joining them in their endless crusade. For those who stayed, the Brothers left behind the Speakers of His Voice. These twisted preachers gave the former drudge new hope, and told them not of a distant corpse-Emperor but of a Grandfather who loved them, always and ever.
      Grandfather had saved them, Grandfather had uplifted them. His love had set them free.
      When word of the Thorn Moons and their strange wonders came, the Speakers saw their true calling; a lovely addition to Grandfather's Garden, a gift to be offered for the many favors he had bestowed upon them. They went to the mines, they went to the cities, they went and called forth the faithful. The governor had left behind many wonders; forges the faithful had toiled at their whole lives, and grand spaceships. It was providence.
  • Who's Online   11 Members, 0 Anonymous, 0 Guests (See full list)
