Couvs
Metal minis - repositioning bent parts
It's going to be a while before I get to painting this, but I was drawn in by this month's 25th anniversary mini, Eli Quicknight, and ended up ordering some more paint colours and another bones mini.  I noticed when looking at Eli in the package that his left hand dagger is bent backward and I'm wondering can I use the same method with boiling water to straighten it out like with the Bones or is there some other thing I should be doing when I do get around to starting in on him? Kinda terrified of snapping the blade clean off.
You should be able to just carefully bend it back into shape without boiling, etc.  Just take it slow.  Most of the metal minis will terrify you a bit the first time you do it because you can "feel" a popping sensation as they bend, but if its just bent a bit and you take it slow, you should be ok.
^^ what Gargs said. Slowly and gently bend the dagger back with your fingers. Maybe use two firm flat objects on either side to really straighten it. It will make a fine crackling sound.
The only warning is to not bend sharply or back and forth. You know how you can bend a metal wire for a while, but too sharply and/or too many times in the same spot, and it will break? Same idea.
Sometimes, you can remove a wavy bend in a blade (for example) by putting a spring-type wooden clothespin over the blade, holding it tightly closed and pulling it over the blade.  No guarantees, but it can work if it isn't too messed up.
Take note of the 'popping' or 'creaking' feeling you get when you bend the part back into position.
If you ever bend a different mini, and the operation feels 'smooth' it was most likely one containing lead.
Oh, and the first time is the scariest...
Yeah, that's a good warning. My dad's old leaded figures are smooth and not crackly. They are also a darker metal than the pewter ones, and more easily scratched. Gotta remember to wash hands after using leaded figures. Don't want to go the way of Rome with lead poisoning.
