Hi everyone,
I need your help.  I feel as if I am at a bit of an impasse. I am currently painting an armed force of ancient skeletons.  The primary reasons for taking this project was to practice my OSL on the eyes, and trying my hand at verdigris for the first time.  I love how both the skeletons and the ancient metal are coming out.  However, I feel as if there is not enough contrast on the models, and when viewing them from tabletop distance, they look too... homogeneous.  Do they look "boring" to anyone else? Does anyone else have a suggestion for how to fix them?
Your bones look very clean. You might add some brown stains or dirt.
They look great to me. I do see where you're coming from though, the homogeny comes from the fact that the bones are a uniform color. Try experimenting towards a browner tone on a few others and mixing them into the ranks. The verdigris looks good as well, but on the next ones tone it back a bit so that more of the copper shows through.
I think they look fine as is but you could try make some skeletons dirtier. The idea being that some came from tombs but some had to claw their way out if the dirt.
I would definitely do one more highlight with a lighter-color bone.  Looking at the figures, I see a base color, and one highlight.  I'd want to go darker, as well as lighter to really push the contrast.
I'd also apply some light glazes to various parts of the figure.  For example, you could do a very thin green glaze, or a red-brown glaze.
Note that these are glazes, very thin, just a touch of color.  The idea being you want to add variety without overpowering the base color.
Do a search for "James Wappel" and then search his blog for "skeleton."  You'll get lots of ideas.
You could also use a ivory-color to do some of the highlighting, which would leave the base grey-bone but provide some difference between the figures.
I’d suggest adding some pops of color; some reds or yellows would contrast nicely.  Either in the form of shield decorations, or spotty residual paint on helmets and bows.
From a tabletop distance, you lose an incredible amount of detail. You know all those hours you've spent slaving on getting the eyes right? Nobody's gonna see them.
Here's a crazy example of glowing eyes -- a tattoo. Notice how much contrast there is in the eye socket. But, to see it, you're going to have to look up close at the miniature. Your picture is still not close enough to see the glowing eyes. At best, maybe paint the eyes black and dot them with a tiny fluorescent or neon color, gradually adding more brightness to the paint.
I think they look great especially the verdigris effects. In addition to what others have said, maybe they will look less homogeneous once the basing is completed?
When painting for tabletop, it is usually good to emphasize contrasts and overdo certain details.
as stated above, some more highlight and completed bases should help.
I you want variety, different base colours beneath the same washes and highlights often do the trick when the minis otherwise are similar.
I would in addittion suggest stark or pure white on the teeth to make them stand out properly.
Just do the bases, it’ll make the skeletons pop just by that.
Loth
Good idea on the teeth- I think I'll do that and the bases too.
    • By LarsM
      This is my first go at using chipping medium, and in all an experiment with weathering.
      Just wanted to share my experiment with everyone, do not really consider this as a tutorial as I did not know what I was doing. :o)
      1. A piece of a blister pack plastic, prime black, and painted a mix of Black Brown and Dry Rust.
      2. Wet blending with following colors in random pattern; Black Brown, Wet Mud, Explosion Orange.
      3. Wash with mix of Flesh Wash and Dark Red.
      4. Stipling and a bit of wet blending with Wet Mud and Explosion Orange.
      5. Wash with mix of Flesh Wash and Wet Mud.
      6. Adding Chipping medium to the top and water and salt to the bottom.
      The idea with the salt is that it can be peeled of later to leave 'paint chips'. But I only seen it achived with an airbrush, so wanted to try it with brush.
      7. Green paint, couple of layers. Way most of the salt fell off, leaving only the very small pieces, they do give a good structure of rust-bubling paint though.
      8. Water to start the chipping. I ned a bit more patience, so the first chips went too deep and removed some of the brown paint too. And to get the chipping look good seems to need some practice..
      I used a tooth brush and a tooth pick to scratch the green paint off.
      9. 'Repaired' some places with stipling of Wet Mud and Explosion Orange and a wash of Dry Rust.
      10. Added streaks with Strong Tone and Dry Rust. And made the rust patches darker with Dry Rust.
      Those streaks really breathed life into the decay.
      Done!
      Came out allright, but the streaks seems to be making a big difference.im
    • By Spooktalker
      Hi all, I thought you might like to see the Mordheim gang I just finished, particularly because it features a bunch of Reaper figures. It's hard to believe I started this over ten years ago. They sat around for years with a good portion done, and lately I've had my old projects in my sites and am finishing them off.
      Mordheim Undead Gang
      I wrote about them and shared more pics in a blog post here: https://belchedfromthedepths.blogspot.com/2018/06/mordheim-undead-gang.html
      More pics of the reaper ones:
      Reaper Matthias the Twisted, Vampire
      I shared the vampire already here, so you may have seen him already. New backdrop with this pic for consistency.
      Reaper Gravedigger
      Reaper humans are too tall, IMO, to mix in generally with Mordheim figures, but the vampire and gravedigger are conscious exceptions as they fit right in towering over their fellows.
      There was no way I wasn't going to have this Reaper monkey in the crew. He's from a familiars pack.
      Reaper Ghouls and Ghast
      Reaper Hellhounds
      Last up are these Reaper hellhounds, or dire wolves, in Mordheim game terms. I was and am thinking of them as black dogs of yore like the barghest rather than wolves.
    • By Othikent
      I did these guys a few months ago.
      I challenged myself when I painted these guys and avoided using washes. I'm very happy with the turnout.
      I'd love to hear what you all think.
    • By TheOldGuard
      Greetings!
      I've been working on this scary Reaper DHL Lich for a week or so. There is a rich blue glowy effect on his eyes but it doesn't seem to have come out that clearly on these pics.
      Anyway, thanks for looking!
  • Who's Online   33 Members, 5 Anonymous, 0 Guests (See full list)
