Hi all,
In case you couldn't tell, I am trying to upgrade my current painting gear to something that gives me more capability to expand my skill base.  One thing I have recently considered is magnification.
I have heard some folks use reading glasses, and a few that use desk mounted magnifiers.  For those that use them, what makes them worth it? (FWIW, my eyesight is 20/20, I am just trying to get closer without putting the mini right into my face).
I use a head mounted magnivisor.  They come in different shapes and magnification and are available at most hobby stores.
  • Thanks 2
I actually bought a desk mounted magnifier, even got one with clips that could hold a miniature but just couldn't get used to it. So I'm still just bringing the miniatures up to my face to paint details.
I use an Optivisor, which is a head mounted contraption, much like what a dentist might use.  Only they're used by hobbyists.  And aren't as expensive as the ones a dentist would purchase.
The usual problems with magnifiers that they're usually small (like, 2-ish inches in diameter), so that you tend to use only one eye when looking through them. This destroys your depth perception, in addition to eye fatigue.
I tried reading glasses, but my vision was bad enough that I didn't get any benefit from them.  Bifocal glasses help, but as I've aged the Optivisor gets more and more use.
Don't go with the cheap version found at Harbor Freight.  You can find a clone at Michaels for $30, or $15-ish if you use a 50% off coupon.
I'm not a fan of the desktop magnifiers.  I think they are hard to use for painting because you have to hold your head at just the right angle, and that can lead to a stiff neck.  Head-mounted magnifiers like the Optivisor are easier to use for me, and since my near vision is not very good, it makes seeing details much easier.  I've used the glass lenses found on the Optivisor as well as the cheaper plastic lenses on a Harbor Freight magnifier.  They both work well enough for me, and I switch back and forth depending on how much magnification I want.  I've read that some people have difficulty using head-mounted mags, but I was able to adjust to one after a short learning period.
If you have 20/20 vision and can see details without any magnification, that's a great place to be.  For you, the main thing I'd be looking for is good light, either natural or daylight lamps.  I like to use one lamp on either side of the desk to minimize shadows.  Then, if you want to try a magnifier, I suggest you try out a pair of reading glasses first.  You'll get some magnification at very little cost, and they don't stick out like the head-mounted mags do.  Depending on where your lamp sits, the head-mounted mags can run into the lamp.  It is something you can adjust to, though.
First, try an Ott bulb or other form of strong LIGHT. I would say that LIGHT helps more than magnification.
Harbor Freight has a magnifier, and it's cheap enough (under $10) that you can see whether or not it works for you. I rarely use mine for, say, eyes, but when I need it, I find it useful.
Again, use a magnifier that has LIGHT. Not one that doesn't use light. One that uses LIGHT. LIGHT LIGHT LIGHT LIGHT LIGHT.
Repeating myself since the last guy who replied to my recommendation didn't get one with LIGHT<_<
Edited by ced1106
I use an Optivisor.
I have also tried cheap copies, but usually get a headache pretty quickly from them.
A proper Optivisor have GLASS lenses, not cheap, cast acrylic lenses, and that makes a lot of difference.
Optivisor for the win.  Only way I would paint.  Great lenses, both eyes, makes painting far easier with good light sources.
I got a headband with lenses.
Works fine and of course I paint under a daylight lamp.
I love my magnifier.  It is easy to keep clean and to position with its extension arm (45 inch reach).  I agree with ced1106 about the importance of the light. I use a magnifier model with a bright fluorescent tube light which is quite cool (bluish).  It's also not hard on the eyes the way I find some of the LED lights mounted on magnifiers to be.  I have a triple fluorescent strip light above my painting desk which has full spectrum bulbs, so the two seem to compliment each other.  I have a daylight lamp as well, but I find lately that I haven't been using it as much because it partly shades out the light from the triple fluorescent.  I do find that I often have to take the miniature away from these lights and bring it close to the natural light from a window to get a sense of what the colours really look like.  When the light is too bright,  I find it tends to make me think the highlights have more contrast than they actually do when viewed under less intense light.
The main problem I find with the magnifier is that I sometimes can't get the right angle with my brush when trying to paint into deep recesses on a miniature because the brush handle collides with the frame of the magnifier.  The other minor problem I had is that the mounting for the lens and bulb is plastic on my model.  I had the tension knobs adjusted too tight so when I went to change its position, the case began to progressively crack and it became less steady.  I glued it back together with epoxy and it's fine now, but I'm thinking that one with a metal case around the lens would be better.   You also have to be careful not to pinch your fingers between the sides of the extension arm when setting it up/taking it down.  There are models available now which have enclosed arms so this is less of a risk.
I'm thinking about getting a visor, but I've only just recently started wearing glasses and I'm still trying to get used to them.
Geoff
I use a magnifier lamp. It is adjustable so I can change the angle. I think it is actually for doing embroidery but works fine for painting. I actually have 2. One has a little clip which is nice if I have printed something off for reference, I can clip it and have it right there to look at. I used to have 20/20 vision until I got old! I could paint wearing just my glasses but the combo of light and magnification makes it so much less strenuous on my eyes and let's me see better what little bits and bobs are on the minis.
Well I used to use an opitvisor  and some low power reading glasses. I was always having to flip it up when ever I needed to mix paint etc. now I just use high power reading glasses and like a lot. Don't get any headaches as before from any bands around my head and I just keep them on the tip of my (big) nose like a granny/grandpa would (which I am the appropriated age for, lol) and when I'm not painting, I'm looking over the lenses at objects, mixing paint, etc.. Oh and I paint with two desk lamps with daylight blulbs about 2680 lumens, one on each side of me.
That's why I prefer the OptiSight over the OptiVisor. I have tried reading glasses and although it allowed me to focus on objects closer to me it provided no magnification that I noticed. Using the OptiSight, looking through the lens gives me a magnified view of the fixed focal point but looking over, under and around the lens is normal view. The downside for you would be that it is still a headband type but I have modified mine to be a tad more comfortable.
I am torn on magnifiers. They are great but I found after I got into the groove of it that I could hardly look at a mini without magnification since it was so powerful. Honestly if you've got a lil cash burning a hole you can cheaply test both head mounted and desk (I picked up one of each for a total of $20, so $10 for each) and I'll probable upgrade to a better headset soon.
I like the headset more then the desktop magnifier; although I'll argue the stiff neck issue a bit. My biggest issue with the desktop is when you find a good spot that allows you to use proper posture it means you'll constantly be putting your arms in the same spot which leads to sore arms. Headset is by far more useful. AND even with hawk-like vision the magnifier (depending how strong) can be so strong you'll legit be watching the very drops of paint transfer from individual brush bristles to the mini, top notch maximum control and a really cool sight to behold. Just be warned it'll spoil you on what minis can look like but it multiplied my skill multiple times over. I went from ok to good just by magnification,
edit to add the 2 cheapies I started with: Headset And  Desktop (but is looks like it's priced much higher now and probably not worth it)
Edited by OneBoot
Removed commerce links
    • By NomadZeke
      Please use the full SKU and name of Reaper minis in the titles of your Show Off threads, per forum guidelines. You can find this information on the blister card or in the online store. I also like to give credit to the sculptor in a tag, so people can find their favorites.
      We have a high volume of posts generated from this challenge, which is great! But it's also creating a lot of work for the mods. Ladystorm has already urged folks to comply with these guidelines.
      As an experiment, this project has been moved to be a bi-monthly challenge again, that seemed to have worked so until further notice that is our format. The longer time frame theoretically will give less stress to painting, and allow more complex jobs, and more sinister challenges.
      FAQ
      Reaper only? - No.
      If going on vacation, can I paint a mini(s) ahead to cover that time frame? - Yes.
      Are speed paints acceptable - Yes.
      Can it be a mini started previously? - Yes.
      Based or unbased? - Yes.
      Do minis for exchanges count? - Yes.
      NEW RULE - Size Equivilancy
      (This list is subject to change as bones 3 releases)
      Medium and smaller = 1 ea
      Simple Terrain (plain floors, walls) = 1ea
      Complex Terrain (http://www.reapermini.com/OnlineStore/Terrain/latest/03518 or such) = 2 ea
      Large (Giants and the like) = 2 ea
      Huge (Most dragons, Demon Minotaur Lord, etc) = 3 ea
      Bigger (Kally, Khanjirra, etc) = half of quota rounded up
      Colossal ("Tianot,") = quota
      Due to the variable nature of a CAV I compare them against a generic 28mm figure and the Avatar large figure. I take height and bulk into considering if it is worth 1 or 2 figures.
      If it's not in this list, it counts as 1. (not yet updated for the CAV II figures)
      If you have a question on the size, please post it here, and I'll address them individually.
      Much like last year, the idea is to help those of us that normally paint VERY little or not as much as one would like, to start painting more.
      You challenge begins...now!
      And Our Mantra:
      Participants:
      If your name is missing, or you believe your count is incorrect, please PM me. Please note: to make counts easier, post in the bi-monthly thread and include the tag RPChallenge
      The objective:
      To paint 52+ minis throughout the course of the year via bi-monthly quota
      (each bi-monthly thread will have the quota listed as well as the master list)
      What qualifies:
      Darn near anything!
      Reaper/non-reaper!
      Any material!
      Shelf of shame minis from ages long forgotten!
      Exchange minis!
      Speed paints!
      Armies! (Though I'd encourage perhaps something outside the army as well)
      Any Size!
      Based/unbased!
      Etc! (I think that covers everything)
      Jan/Feb: 8: http://forum.reapermini.com/index.php?/topic/84372-january-february-rpchallenge/
      March/April: 9
      May/June: 9
      July/August: 9:
      Sept/Oct: 8:
      Nov/Dec: 9:
      Again, I request that when tagging your posts, please use "RPChallenge" to help with locating minis from this.
    • By NomadZeke
      [MOD]Please use the full SKU and name of Reaper minis in the titles of your Show Off threads, per forum guidelines. You can find this information on the blister card or in the online store. I also like to give credit to the sculptor in a tag, so people can find their favorites.
      We have a high volume of posts generated from this challenge, which is great! But it's also creating a lot of work for the mods. Ladystorm has already urged folks to comply with these guidelines.[/MOD]
      As an experiment, this project has been moved to be a bi-monthly challenge last year, that seemed to have worked so until further notice that is our format. The longer time frame theoretically will give less stress to painting, and allow more complex jobs, and more sinister challenges.
      FAQ
      Reaper only? - No.
      Bigger (Kally, Khanjirra, etc) = half of quota – rounded up
      Much like last year, the idea is to help those of us that normally paint VERY little, to start painting more.
      And Our Mantra:
      Participants:
      If your name is missing, or you believe your count is incorrect, please PM me. Please note: to make counts easier, you must post in the bi-monthly thread.
      The objective:
      What qualifies:
      Darn near anything!
      Reaper/non-reaper!
      Any material!
      Exchange minis!
      Speed paints!
      Any Size!
      Based/unbased!
      Jan/Feb: 8: http://forum.reapermini.com/index.php?/topic/78658-janfeb-rpchallenge/
      March/April: 9: http://forum.reapermini.com/index.php?/topic/79997-marchapril-rpchallenge/
      May/June: 9 Oops.
      July/August: 9:
      Sept/Oct: 8:
      Nov/Dec: 9: http://forum.reapermini.com/index.php?/topic/82946-end-of-year-rpchallenge-oct-nov-dec/
    • By NomadZeke
      Pretty certain at this point I fell off the wagon got ran over by it, then chased it down and set it on fire (given the drought of these - explanation is in the chatter thread)
      Please see the main post here for rules, questions and general chatter, while using this thread to keep a list of links to your show-offs or show-off related comments in a single post: A reminder to please adhere to miniatures posting guidelines as usual.
      http://forum.reapermini.com/index.php?/topic/78657-resolutionary-painting-challenge-2018-chatterquestions/
      All the information you need should be here.
      Due to the delay, there is going to be a normal and hard challenge for each month.
      Your challenge is: 13!
      October Bonus: This is Halloween! - Paint a mini using only colors that have black, orange, and purple in the name. You may also use "Fresh Blood" and "Spectral White" as they are part of the monthly promotion.
      Hard mode: Jack-o-lantern's light - Paint a mini where the only source of light would be coming from inside a jack-o-lantern. Pumpkin may be part of the mini/base or sculpted
      November Bonus: Festive feast - Since both US And Canada have their Thanksgiving in this time bracket - paint up a mini (figure or terrain) to have some food being presented
      Hard mode: Liquid Cheer - This can be done with the above - paint a mini where it's holding a drinking vessel - but paint it as though the mug were glass and you could see the drink inside from the sides (in theme - ale or wine is the best use)
      December Bonus: Winter Solstice - To celebrate the shortest day of the year - paint a halfling or dwarf decked in wintry colors (think blues/grays/whites, maybe brown and a little bit of evergreen)
      Hard Mode: Gift wrapped - paint a mini with any inorganic parts (metal, cloth, etc) being done to resemble giftwrap - little candy canes, trees, text, stripes, etc - bows optional
      Good luck
      The game is made up and the points don't matter
    • By Rat13
      I've made no secret about my opinions on Games Workshop. Though my painting box is full of their miniatures they were always bought second and sometimes third hand (I never wanted GW to get any of my money). Even my previous Cadians were bought from my local games store that has no affiliation with GW (I also know those sets and blisters came with the business when it was bought almost twenty years ago). Now I find myself in the unique position of building a Cadian army.
      My wife and I used to play weekly in D&D Adventure League but with the birth of our first child it looks like that won't be possible (We want to continue gaming at our current store but its a bit of drive and the kid is at the rolling stage so she doesn't want to be held or sit in her seat; she wants to be on the floor and we all know what gameshop floors are like). I've offered to watch the child so she can go or to switch off each week but she only wants to go together. Gaming together has always been part of our relationship, and she doesn't want to lose that. I couldn't agree more, its good to share a hobby with your spouse.
      That's when our friends started trying to recruit us to play Warhammer 40K with them. At first I was resistant but our friends get together often to play and in our area its always possible to find a game (Depending on the size it can be played fairly quickly in comparison to D&D too). After some discussion we decided 40K would give me something to paint, but it would also give us both something to play and eventually something to play together.
      Which brings us to this new project. Since I figured watching me assemble miniatures would be pretty boring I'm starting this thread right before I prime them. So here is most of my assembled starter set (I've got quite a few cheap sets of bits arriving over the next couple weeks and I'm not exactly sure what unit I'd like to create next so that's why I have so many unfinished figures).
      I'm still not a big fan of GW but having an excuse to see our friends more often is pretty nice. In a way we're kinda trading one gaming group for another (that sounds pretty mean but I think you understand what I'm saying).
    • By Chris Palmer
      I bought into the recent Terrain Crate Kickstarter; getting the Dungeon Crate, and the Battlefield Crate, along with the Dark Lord's Tower set.  My Terrain Crate shipment arrived in the early Summer, and I immediately painted two of the large tents that came with the "Campsite" portion of the Battlefield Crate to use in a game I did at Historicon.  Recently, I've been painting some of the "Abandoned Mine" stuff from the Dungeon Crate, as I am preparing for a game a friend and I are doing at Fall-In using our Tablescapes Dungeon Mines sets.
      I thought I'd start a thread to chronicle the pieces I paint, to help me keep track, and to help keep me motivated to keep plowing through.  There's a lot of pieces!   I hope to use a bunch of it in my Fall-In game, so have some motivation there as well.
      Big Tents:
      The Terrain Crate stuff goes great with the Tablescapes Dungeon Mines sets.
      Explosives:
      Tool Racks:
  • Who's Online   24 Members, 1 Anonymous, 0 Guests (See full list)
