JGroeling
Market stand, questions for working w Balsa wood
Decided to put together a little farmstand scene for a basing project. Split pieces of balsa wood to give a rough lumber approach, now I'm considering how to do painting/sealing on it, as I have minimal experience w Balsa.
Want to keep all that little wood grain that popped up when I split them visible. Going to paint it slightly darker with acrylic browns, and then some slightly darker spots and lighter drybrush highlights to accentuate the grain.
Should I gesso, or stain the balsa before working on it?
Can I just work straight on it and seal it with a varnish afterwards?
Any balsa wood experience/suggestions appreciated.
My experience is that after working it I sealed with typical mini sealer. Little loose slivers would lift from the wood near straight out and I would have to sand them down or cut them off. Some I couldn't really get to. I found that was because the sealer was too diluted, so I recommend you lay it on heavy or thick, don't thin it unless you can sand it after. My sealer seemed to darken the wood too. Maybe try a test peice and see how responds to your materials. I also recommend sealing it before painting it, the wood absorbs a lot of paint and it is very unpredictable how this occurs so some grain might become more pronounced than an area right beside it. Sealing it before painting should prevent that and let you get the colors on the wood just the way you want. The rougher the wood the worse the effect is. But if you're looking for a worn, used look, you might like that effect. Cut edges take the paint pretty well compared to the long face boards so keep that in mind.
I would think some thinned brown liner and a big brush would do the trick.
Regardless, you need a sign: "the doctor is in" (and of course, the 5¢ tag)
  • Haha 3
The stall you are looking for is around the corner and across the children's play field. Honestly I'm not so sure that treatment is worth the 5¢, but to each their own.
  • Haha 3
Played around with some scrap last night, liked the results I got from priming w black gesso and layering browns over that. Still need to paint the base and design on the signs portion. Also have some sculpting to do for the wares that will fill the shop. Lots to do.
The two unfinished planks are boards I was using to test materials on.
  • Like 11
 I like the way that came out.
I've also had mostly good results staining wood with tea or coffee before sealing it.
May try coffee/tea on another project.
For now I'm building out the stuff to fill the space. Will update in another week or two w progress.
    • By Lidless Eye
      A collection of Dwarven terrain designed by Printable Scenery.
      All pieces were printed on a Creality Ender 3.
    • By Lidless Eye
      Here is some more of my recently painted 3D printed terrain.
      Shattered Tomb Entrance, design by EC3D:
      Rock Pools, by Duncan Shadow
      Scatterblocks: Dwarven Fountain, designed by dutchmogul
      Ironhelm Bastion Ruins, designed by Printable Scenery
    • By Lidless Eye
      I've painted another set of terrain, the wonderful "Ulvheim Buildings & Ruins" designed by Terrain4Print
       All were printed on my Creality Ender 3.
      They seem quite at home for Mordheim or Frostgrave.
    • By Lidless Eye
    • By Gadgetman!
      https://www.kickstarter.com/projects/1280484354/world-of-twilight-the-crooked-trade-outpost/comments
      About
      It’s been 20 years since my first sketches of the diminutive fubarnii and this Salute will be the tenth anniversary of the first Twilight releases! Over those two decades I’ve visited large areas of Anyaral and we now have well over 100 unique playable units for the game (not to mention all the different variants, civilians and a wide variety of critters...), all in the usual World of Twilight scale (roughly 28mm).
      If you are new to Anyaral, then I recommend you go and visit the World of Twilight website to find out more!
      Over the last year I’ve continued with the normal range, but I’ve also had a play with something slightly different, and that is where I need your help!
      Legends of Anyaral is a random little side project that will let me play with big buildings and creatures that simply wouldn’t work in the usual scale. I took the very simplistic approach of sculpting everything half the usual size, which effectively makes it a 15mm range. The first sculpt I did was of a piece of Fubarnii architecture that I sketched during Inktober 2017; the Crooked Trade Outpost.
      "Crooked" from Inktober 2017 "We paused our travels briefly at the crooked tower of Geliad. I had initially assumed the tower was on the brink of collapse, but was assured by the locals that it was all part of their local engineer's eccentric but deliberate design! It now serves as an outpost where traders rest before braving the Moerasii marshes. We were fortunate enough to see a domesticated lorsaan being loaded with baggage. It never ceases to amaze me that such behemoths wander our lands."
      I wanted to create the building, but figured it would be somewhat huge in the usual scale! Instead, I halved all the dimensions, making it a much more manageable 135mm in height. Having sculpted the building I did of course need to sculpt the lorsaan to accompany it. Then a few little traders to look after the Lorsaan... Which gives a good insight into how Twilight has generally been created over the last twenty years!
      The Crooked Trade Outpost, painted by Joe Karame I’ve got a few other ideas I’d like to do in the Legends scale (the enarii, more huge beasts!), but it depends a lot how well this project is received. I have no current plans for any rules, although that could be very tempting! That's for the future though, this kickstarter is just about the Outpost :)
      Even in the smaller scale I wasn’t entirely sure how practical it would be to release the trade outpost, but the very talented Rob Huntley (Warploque) took it in hand and did an amazing job casting the tower as a single piece kit! I then worked with Rob Alderman and John Bryan to make some more production moulds that would make the set affordable to gamers as well as collectors. For this kickstarter most of the pledges will be cast by John Bryan, but I am also giving you the opportunity to get your hands on the Warploque master casts as a special collector's edition.
      I’m keeping everything about this campaign simple. The campaign will run for a short period and will be very focused. I’ve got a couple of ideas for extras and stretch goals (remember those traders I mentioned earlier...), but nothing that will delay delivery!
      As soon as the campaign is over I’ll get everything ordered and get the pledge manager open so I can start shipping as soon as Kickstarter release the funds.
      I’m sure many of you in Europe will be a bit apprehensive about Brexit. I can't make any promises as there isn't much time, but the plan is to get all European orders shipped first (hopefully before the end of March) with the orders to the rest of the world close on their heels!
      For this Kickstarter I’ve come up with a few simple pledges, so you can get the Lorsaan or the Crooked Outpost, or everything together.
      I've also put together a special Master Quality Collector's Set, which is the definitive collector's edition. The Collector's Set includes resin Warploque master casts of the Trade Outpost and the Lorsaan.
      Risks and challenges
      We've run three larger projects previously, so have a good grasp of the challenges involved!
      This project does involve a lot of individual resin casts, which I know can cause production delays. However, I’ve lined up the casters so I’m confident they’ll be able to deliver in time.
      The other concern is the impact Brexit might have on delivery for European backers, but we will do our best to get European orders out in advance, as long as details are provided efficiently.
      It's a small, short-time project, so hurry up to back it if you want it. Only 4 days left.
  • Who's Online   39 Members, 2 Anonymous, 276 Guests (See full list)
