Brianuk
Frostgrave rough ground, noticeboards, and ruin work in progress
Very nice, I particularly like the job boards since those are things we don't see all that often.
Thanks everyone. Here are some more WIP shots of the ruins including a new one. Again these are quarters of a clementines box with rollered foam added to the outside. I am not adding foam to the insides to avoid over engineering and to make sure that the floor work/balsa is being stuck to wood, not to foam.
I need to varnish or add a water effect to the well and also blend in the stones that I have picked out in lighter grey. I will run a vine or dead tree down the exposed corner section in the last photo, where you can clearly see the old joins in the wood.
A challenge I have is that I am washing the stonework with black ink wash and it darkens things down a bit too much. It obscures the times when I actually highlight things properly! It might be that this doesn't matter when I add snow effects.
  • Like 12
Have made some rubble piles just by taking the cardboard tops to the decopage ocean liner models I brought (the bottoms are turned into boats) and then sticking foam bricks and rubble onto them. This is a good way I find of using up the scraps from making the buildings and other terrain with pink foam. There are a couple of scibor basing bits on there as well.
Painting was drybrushing with craft acrylics. Then I made an ink wash following the method in the Lukes APS videos on YouTube. I wanted a grey wash so mixed black and white ink with acrylic medium and deionised water. Will see how it dries but hopefully it gets over problem of me shading everything very very dark grey.
Final step is probably to add some bits of lichen and tufts and maybe some snow patches.
Oh and there is a dorky joke in there if you look hard enough.
Now with some lichen and tufts, have decided not to add snow so in theory could be used for Ghost Archipelago as well.
  • Like 8
Cool rubble and ruins!
Dorky joke (in spoiler in case others want to look for it)
Tetris blocks?
Ruins nearly finished, just need to add some tufts and fake snow, and pay a bit more attention to the floor.
Have used the homemade grey wash again and am much happier with it than using black ink wash. Also have been using domestic filler to smooth over gaps in the materials. The wood is just painted with Vallejo "wood grain", am happy enough with it but might weather it further.
The only flaw terrain wise is that no one seems to have put any windows or doors in any of the unruined buildings...
    • By Dan d'Lyon
      Didn't see a topic for this one, and thought there might be some interest.
      https://www.kickstarter.com/projects/rocketpiggames/tilescape-gothic-city-3d-printable-modular-buildin?ref=profile_starred
      About
      Tilescape 2.0 is a modular building system which allows for the ultimate customization of terrain. With our system you will have total control over your structures. There are several unique possibilities for your floors, streets, buildings (inner and outer walls), accessories, and roofs.
      ~ Intuitive/fast building single piece tile system
      ~ Modular vertical walls insert-able walls/posts/columns
      ~ Insert-able doors and windows
      ~ Insert-able accessories and decorations (curtains, traps, etc)
      Gothic City is the newest completely customizable terrain project from Rocket Pig Games. We provide you with the .stl files and you bring them to life on your 3D printer. It utilizes our Tilescape 2.0 building system which features totally modular building components from the ground up!
      ~ Universal and Versatile Set will work well with many types of gaming!
         (Call of Cthulhu, Iron Kingdoms/WarmaHordes, Malifaux, DnD, Steampunk,       Victorian/Gothic settings, etc)
      ~ The Biggest Lovecraftian/Gothic horror monster miniatures ever made!
      ~ The most complex roof system available anywhere!
      ~ Make unique buildings in any shape and size!
      ~ Only modular system that has authentic medieval overhanging building
         floors.
      ~ The Gothic City Streets Core set also makes an a very good Dungeon tile-set.
      ~ Gothic City supplies everything you need to create a full medieval or
         Industrial Fantasy city!
      ~ Our unique and varied wooden floor planks, whimsical stone alleys, and brick streets can be used in their traditional way or as building interior floors, pathways, or balcony flooring.
      Gothic City Buildings & Streets Limitless options for building shapes, types, and sizes! Make amazing streets and ally-ways with unique tiles! Create villages, cities, or forest cabins with our generous selection of stone and wood walls and roads! ~ Our modular interior walls are insertable and can be arranged however you see fit and the exterior walls can soar to great heights or expand in any direction. Add dimension to your landscape by making your buildings as tall or as short as you want!
    • By Brianuk
      Made up these market stalls and goods from Mantic Terrain Crate range. There were the well documented problems with the spindly supports to the stalls being completely bent. Hot water didn't fix the bigger stall so I had to stick additional supports on to it as a frame, made from matchsticks and mdf sprues.
      Enjoyable painting up the tiny goods on display though and overall would still recommend product. Would be interesting to see something like it in Bones.
    • By bluecrowlaura
      Hello all! Here are a few pics of my second official terrain project. It's a castle/boss chamber, I suppose. I didn't really have anything in mind when I started building it; I was just fooling around with my new molds, tinkering with dry stacking. This eventually emerged.
      I built it using Hirst Arts molds and bits from both Reaper and Mini Monsters. The Reaper parts are Large Sarcophagus (77540) and parts from Magic Treasures II and III. I made the flags from salad container plastic and various bits; one of these days I would like to go back and paint more detailed flags and replace these. I see so much amazing freehand banner work and I have artist envy...!
      Happy painting,
      Laura
    • By kristof65
      This is a test piece for some ruins I'm printing and assembling.  I may have gone a bit overboard on the vines.
    • By justcallmej
      Citadel for 3D Printing on Kickstarter
      Review with test prints at Haldane Creations
      Funded and many stretchgoals Open
  • Who's Online   31 Members, 1 Anonymous, 0 Guests (See full list)
