Using non-white glue for sands?
Shin Okada
Hi! Every "how to" books I have read are suggesting white glue (or PVA glue) for applying scenery materials such as flocks, sands, and static grass. Is it impractical to use other kind of glues? I am wondering if using 2 part epoxy glue for sands is a good idea. PVA glue takes so much time to dry.
Thanks in advance.
  • Replies 27
I've never used two-part epoxy, so I can't answer that part. However, I've used CA glues to apply all of those things, and it seems to work fairly well.
I wouldn't recommend CA glue for field grass, as the capillary action will cause your entire clump of field grass to be stuck together from top to bottom.
I used thinned down white glue for applying grass and weeds/turf. For tall grasses, I use a hot glue gun, and for attaching sands, rocks to the base and to seal my cork I use thinned down carpenter's glue...
But that's just me. ::D:
I haven't used two part epoxies for anything other than attaching the minis to bases or to uber-bond the pinned parts of a mini.
Usually I don't have any longer drying time than you would with 5 minute epoxy with my thinned down glues. But then, I just use small amounts to get the job done.
CA will work just fine for sands and stuff....just get your placement right...and use a *liquid* not a gel. The only thing I would caution against is some glues dry with a color that can detract from the scenery. If it dries clear, and the fumes won't kill you, use it. It's easy enough to test flock and such on a piece of cardboard....
For adhereing static grass and other items to a base like small pebbles and clump foliage I just use some brush on Delta ceramcoat indoor/outdoor matte sealant. It works like a charm and dries at a decent rate, plus when dry it is going to resist moisture. PVA glue on the other hand will not resist moisture and will absorb it, possibly weakening the glue.
