shakhak Posted February 27, 2006 Share Posted February 27, 2006 More or less the samething that happened to Ashcrypt. In the army that is built for the Maiden in the box set it lists Bolt, and says to use it defensivly. So just an army compilation error, or is she also meant to have Def. Magic? Quote Link to comment Share on other sites More sharing options...
Tranari Posted April 2, 2006 Share Posted April 2, 2006 More or less the samething that happened to Ashcrypt. In the army that is built for the Maiden in the box set it lists Bolt, and says to use it defensivly. So just an army compilation error, or is she also meant to have Def. Magic? I've been wondering much the same thing. Why does the included list put Bolt on her at all if she doesn't have the SA to use it? I'm just going to asume that she has def mag. Quote Link to comment Share on other sites More sharing options...
spiritual_exorcist Posted May 5, 2006 Share Posted May 5, 2006 Can this issue be addressed officially so that it might be included in the FAQ if needed. Thank you. Quote Link to comment Share on other sites More sharing options...
spiritual_exorcist Posted May 24, 2006 Share Posted May 24, 2006 Looking for clarifation so this can be added to the FAQ Quote Link to comment Share on other sites More sharing options...
Emmel Eitch Posted May 25, 2006 Share Posted May 25, 2006 More or less the samething that happened to Ashcrypt. In the army that is built for the Maiden in the box set it lists Bolt, and says to use it defensivly. So just an army compilation error, or is she also meant to have Def. Magic? she does have the Defensive Magic SA Quote Link to comment Share on other sites More sharing options...
