wal enalut Posted March 28, 2008 Share Posted March 28, 2008 From Reading the discussions on area effect spells, I started thinking about soem other areas that I am not sure what is beign measured to: 1) In a ranged attack: do you need to draw a line to a base or do you need to actually hit the middle? 2) In an area effect ranged attack (blowthrough) do you need to clip the base or do you need to hit the middle of the base? It seems to me that a consistnet rule would eb best (for at least these 2 instnaces and preferabley for all area effect affects). Quote Link to comment Share on other sites More sharing options...
Vil-hatarn Posted March 28, 2008 Share Posted March 28, 2008 Area effects have to be center. Other measurements, I'm not actually sure...CAV uses center of the base, that's probably best. Quote Link to comment Share on other sites More sharing options...
vejlin Posted March 28, 2008 Share Posted March 28, 2008 yeah AoE is measured by center of the base while other distances are edge to edge. Quote Link to comment Share on other sites More sharing options...
Hellsgate Posted March 28, 2008 Share Posted March 28, 2008 Some line AOE just have to touch, but it says so in the discription: Blowthrough:"...Any Model's base touched by this line is in the AOE..." Lightning Bolt/Blast:"...Any Model whose base is touched by this line is affected by the spell..." Quote Link to comment Share on other sites More sharing options...
