OutriderHobbies Posted August 13, 2012 Share Posted August 13, 2012 Hey everyone. This is an idea I've had for a while that I would love to offer for the Reaper Cases, but I would also like to make it the best layout possible. So with that in mind, I've come to you all for help. Basically, what I'm looking for is, if you are a DM/GM/whatever, what would you consider a must have for any kind of kit? Remember, it all has to fit in a case the size of the current Reaper cases. I'll do one for the Kickstarter case later, but for now we're starting with this one. So with that in mind, I await your suggestions. Quote Link to comment Share on other sites More sharing options...
Qwyksilver Posted August 13, 2012 Share Posted August 13, 2012 Space for dice. Pencils and markers. Beads/tokens. Miniatures. Maybe tape measure. Thinking for army transport as well which the lunchboxes would be better. I think for a GM until you get the bigger KS case it won't be as useful because the lunchbox ones aren't big enough for books or notebooks. Quote Link to comment Share on other sites More sharing options...
Baphomet69 Posted August 13, 2012 Share Posted August 13, 2012 Yeah, an...equipment...kit would be cool, but it would be hard to do in the smaller case. All the things Qwyk listed, but if that was it in a small case, I don't think that would go over well... Quote Link to comment Share on other sites More sharing options...
OutriderHobbies Posted August 13, 2012 Author Share Posted August 13, 2012 Don't worry, I'll be working on an option for Warlord too. This is just on my "want to do right now" list. Waiting on a box from ReaperBryan before I tacle that. Anyways, this is intended more for something to toss in your backpack with all your books. Keep things a bit more organzied. What's the minimum number of miniatures you would want to se in this? Quote Link to comment Share on other sites More sharing options...
Arachne Posted August 13, 2012 Share Posted August 13, 2012 I agree with them up there, and I'd say a half a dozen to a dozen miniatures, at least. Quote Link to comment Share on other sites More sharing options...
Ulsif Posted August 13, 2012 Share Posted August 13, 2012 A case big enought for at least 30 minis, usually between two or three large encounters, and at least 4-5 a bigger minis. Dice, markers, possibly some loops on the outside to put a rolled up battlemap in. A soft side case that could hold a 2-3 rule books in pockets, along with notes would not be bad. Quote Link to comment Share on other sites More sharing options...
Qwyksilver Posted August 13, 2012 Share Posted August 13, 2012 3-6 big spaces for large/huge critters. As many damned human sized as possible with the space left. Space for about 20-ish dice. Space for 4 dry erase markers and pens. Space for some tokens and/or condition markers. 1 Quote Link to comment Share on other sites More sharing options...
Baphomet69 Posted August 14, 2012 Share Posted August 14, 2012 Even a DM case with space for pens/pencils, dice, tape measure, etc. and enough space for the party figures, then the DM could use a separate (larger) case for the NPC minis? Spitballing here.... 3 Quote Link to comment Share on other sites More sharing options...
OutriderHobbies Posted August 14, 2012 Author Share Posted August 14, 2012 Spitballing is good. I don't claim to know exactly what everyone will want. I'm thinking this one as either a fiddly bits box to keep everything organized. I definitely want to come up with options for the Kickstarter case, and the cases I currently offer. The purpose here is to get a baseline when I'm moving forward. Quote Link to comment Share on other sites More sharing options...
Arachne Posted August 14, 2012 Share Posted August 14, 2012 Yeah, a case to hold all the encounters would be good, larger and smaller, compartments and all would be great, but separate from the DM junk stuff. Quote Link to comment Share on other sites More sharing options...
Qwyksilver Posted August 14, 2012 Share Posted August 14, 2012 I figure for D&D 4th its usually 2 or 3 encounters per game session. Usually there is some continuity between encounters so you can have overlap of foes. If you can get space for about 20 models plus supplies I think you'll be okay unless its a huge mob type scenario. Or maybe a pack that can hold 10-15 PC & critical NPC/summons/companions plus supplies. And then a monster pack for multiple encounters. Quote Link to comment Share on other sites More sharing options...
dwarvenranger Posted August 14, 2012 Share Posted August 14, 2012 For just exsisting boxes, I don't think that you'd be able to do a DM justice. Unless they use a lot less books than I do, which is inconceivable! But as a player, a cut out for one or two standard sized minis, and cut outs for a animal companion or mount perhaps. A cut out for a couple of pencils and markers and perhaps one or two cut outs for dice and other oddities would be enough for me. Quote Link to comment Share on other sites More sharing options...
OutriderHobbies Posted August 14, 2012 Author Share Posted August 14, 2012 @dwarvenranger - That's a fantastic idea. I had never thought of a Player Kit. Obviously a good mix of ideas here. Quote Link to comment Share on other sites More sharing options...
Qwyksilver Posted August 14, 2012 Share Posted August 14, 2012 The player kit is perfect for the lunchbox. Quote Link to comment Share on other sites More sharing options...
Jordan Peacock Posted August 14, 2012 Share Posted August 14, 2012 For miniatures: I'm a real fan of "pluck foam." I've got so many oddball miniatures that it's impossible for any standard layout to just happen to have all the right slots to hold them all. If there were a space for the "GM kit" assigned for minis, it would be nice if it's done in such a way that it can be easily customized. I suppose if you had a bunch of small squares meant to hold typical "human-sized" minis, it would be pretty easy to tear out a few dividers between them to make room for a mount or larger model as necessary; perhaps that could be facilitated by designing the dividers as perforated so it's easier to get a clean tear. For accessories: I mostly play Savage Worlds; I have an "army bag" with some zippered side pockets that I use to hold the "star" minis for my games, plus a lot of the accessories. In addition to the typical things you'd use for RPGs (dice, tape measure, pencils), I typically pack: * Standard burst/area-effect templates. Savage Worlds has standard sizes for them, and you can print your own, but I often misplace them if they don't have an assigned space. * Deck of initiative cards. * Adventure Deck (another standard-sized card deck, as an option for Savage Worlds). * Flight markers (some plastic pizza-box spacers with round flat tops -- perfect for perching a mini on to show that it's flying or up in a tree or whatever). * Status rings (some cheap "rings" I get by the bag in the wedding section at the local craft store; I can hang a ring on the head of a mini or on an upraised sword to indicate "Shaken" or other special status). Quote Link to comment Share on other sites More sharing options...
