karpouzian
Making a wash without flow improver...
Ok, so I was looking for flow improver today, and Hobby Lobby and Joanne's did not have it.
I want to make a wash similar to Les's wash recipes...
I have the ink, distilled water, and matte medium, but no flow improver... I've read Future works as a flow improver, also dish soap works...
So, anyone have a suggested recipe with the inks, and matte medium?
Did you ask an employee? I bought mine at Hobby Lobby. Otherwise, there's always dickblick.com!
I did ask an employee. No luck. And if I buy at dickblick.com, I pay 4.99 for the flow improver, and 7.99 for s&h :(
I don't typically put flow improver in my washes, but then I'm usually mixing them on the fly. Is your intent to make essentially make a pre-bottled wash? I think I would go ahead and make it without flow improver and you might go ahead and use Future. Future is the main ingredient the famous magic wash found on Dr Faust's Painting Forum.
You can use Future, but you may get a shiny finish. Any of the big craft stores should have flow improver: Michaels, JoAnn's, Hobby Lobby. Or check out an art supply store. Reaper offers some, too. Essentially, all the flow improver is doing is making the water molecules a little less attracted to one another, and thereby allowing the "pooling" effect to maintain through the drying/evaporation process. In a one ounce bottle, it'll take just a few drops to get the effect.
If you really wanted to, you could use saliva as a flow improver. Not the best option for making a large quantity of wash, but it will work.
I wouldn't recommend Future. It's glossy and will act more like a varnish than a flow aid. I'm surprised neither place had it... You may need to look in the craft paint aisles if you can't get Liquitex or Golden Acrylic artists brands. (BTW I trust store employees to know about their stock about as far as I can throw them! Ask me about my hardware store experiences.)
Look for any of these:
http://www.decoart.com/cgi-bin/Products.cgi?Easy_Float
http://www.plaidonline.com/folkart-outdoor-acrylic-colors-flow-medium/72/product.htm
http://shop.hobbylobby.com/products/folkart-floating-medium-898858/
Reaper has one, MJDesigns, Michaels and Hobby Lobby do typically carry them... of course, REAPER MSP has it in the paint already ::D:
I just got a bottle and found it at Michaels in the artist paint section- not the craft paint section. It was on the shelves under the hanging tubes of acrylics and oils. I was at AC Moore today looking for some jewelry findings (I do a million different things- paint, jewelry, sew, cross stitch, work on my yard haunt year round.... ) and thought I would check out their paint and brush section and did see it there too. I have found Hobby Lobby to be less well stocked than M & AC for painting stuff (but their jewelry department is better) and I haven't had much luck with JoAnn's with a wider range of painting supplies. If you have a Pat Catans near you check there. They are usually well stocked and have a wide variety of craft/hobby supplies.
I wound up going with the Reaper flow improver. I couldn't get anything else locally, not even at the fine art supply place.
Though they had everything else. Weird. Anyway, I think it's good but I'm not sure yet. It's so different from my usual gunk I haven't quite tamed it. Also I have no other brand to compare it to.
But I guess it's probably the same stuff Reaper adds to the MSP.
Well, as far as pre-bottled goes, I'm just trying to get prepared for the gajillion billion minis I'm getting from kickstarter... I'll have to look at Dr. Faust's forums, thank you.
  • Will the Matte medium counter the 'shiny' finish of future?
  • Two Hobby Lobbys in my area, and one Jo-Ann's didn't have any flow improver. I looked in the 'craft' paint section, as well as the art paint section.
A simple wash can also be made with Windex window cleaner. Just use it instead of water, it really does work. Airbrush users have been using this method to thin paints for years. The Windex works as a flow improver and does not leave any paint brush markers. The blue in the cleaner does not effect the final colors, and the alcohol in it aids drying time. All the flow improvers I used ended up slowing drying time.
-James
A simple wash can also be made with Windex window cleaner. Just use it instead of water, it really does work. Airbrush users have been using this method to thin paints for years. The Windex works as a flow improver and does not leave any paint brush markers. The blue in the cleaner does not effect the final colors, and the alcohol in it aids drying time. All the flow improvers I used ended up slowing drying time. -James
Also something worth a try...
It should be noted that ammonia can react very badly with acrylics, and windex contains ammonia. Don't use it with any kind of Future gunk mix, and if you intend to use this method you'll have to test your acrylics first. Ammonia can be used as a stripper agent with acrylics, so while it might work with some - be aware of the risk before you wind up ruining a mini because of a reaction.
ETA: There is an ammonia-free version, though.
ETA 2: Experimentation is good, just remember you're playing with chemistry. Safety first, be careful, and watch out for weird reactions between ingredients. If in any doubt, play it safe with materials you know are designed to work together.
ETA 3: Just so you know, mixing Tamiya paints with acetone-based paints may result in toxic smoke, melted plastic, and even fire. Surprised me, too.
    • By Dan d'Lyon
      Well, looks like Hasbro is doing their own version of a kickstarter for a new release of one of the all-time classics.  I don't know if their site for the crowdfunding would be considered as a commercial site, but I'm sure it will be easy enough to find.  I'm in!
    • By MoonglowMinis
      Today I wanted to show off some cheap 54mm Vikings that I painted up as Frost Giants.
      I made these guys close to a year ago, and they were among some of the first larger sized minis I had worked on, so they're a little rough, and that's before looking at the quality of model, but if someone else is in need of a lot of giants like I was, then this might be useful to them!
      So these guys are from Tehnolog, a Russian miniatures company that I know very little about.  The minis are made out of a soft plastic like novelty toys you can buy with tickets at an arcade.  They also have abysmal detail.
      They're meant for 54mm wargaming, and I believe there's an intended game system that accompanies the line, but my goal was to get some cheap giants for D&D.
      They fit nicely on a 2in base, and could probably fit in with the smaller Reaper Bones giants, but they're definitely a little undersized.  I remedied this by giving them each a boosted base, with the leader getting two layers.  At a glance, they tower over a standard medium sized mini.
      The details were rough and there were some ugly mold lines here and there.  But they're serviceable.  They might work better as a half-giant if you want to use 5e's Huge Frost Giants.
      More pictures of each giant below the Spoiler:
      Tehnolog also has a few other lines of fantasy-esque minis if you're a fan of cheap minis.  I am still considering getting one of their other lines to convert into cheap-o Fire Giants.
      What's your favorite obscure miniature substitute?
    • By MoonglowMinis
      So for awhile now I've had this goal, nay, this desire, nay, this primal compulsion to build a boat.  It is not enough to have hand drawn maps, or 2D terrain tiles.  I need a fully functioning 3D boat!  Well, maybe not fully functioning.  But I want to build a cool boat!
      I've been working on a nautical campaign full of swashbuckling, sailing, and sea monsters for a few years now.  It's my White Whale project.  Always just on the horizon.  It'll happen some day, but in the meantime, I have a million small projects to complete and extend the chase.  One of which is my desire to build a few different sized ships to enliven any possible naval combat.
      I actually attempted this about two years ago, just winging it and making some measurements and throwing them at some craft supplies.  I wanted a cheap option that wasn't too difficult to repeat that way I wouldn't be discouraged from making multiple ships.  So I limited it to cheap crafting materials like foamcore, wooden dials, popsicle sticks, and thumbtacks.  And the result wasn't  bad.  Especially for my first attempt at any kind of terrain building.
      It actually turned out rather nice!  To my surprise.  But I got hung up on mast and sail designs and never finished.
      The wood on the deck had 2x1in grid carved into it for easier D&D use.
      and the figurehead was designed to be modular.
      However, overtime the boat collected dust and little scratches.  I should have given it a coat of mod podge or sealant of some kind, but never did.  And eventually it had an unfortunate run in with an injured owl that we took in for a night.
      Here's the little devil himself.
      Anyways, I put this project on the back burner for long enough and feel inspired to dive back in.  Especially with a certain Bones ship on the Horizon that I'm still on the fence about getting.  I was doing some browsing on the web and recently found this wonderful little blog complete with loose instructions and a plan from a now defunct wargamming site.  The blog creator had found the old plan and adapted it to build something using most of the same materials I have already stockpiled.
      There's a few choices that I like better than my first attempt so I think I'm going to use this as some inspiration as I give this boat thing another go.
      My hold up now is still those darn masts.  The original plan above used wood and required drilling out holes for the masts.  The blogger use foam for his ship and found random bits of tubing to house his masts.  I could try to find something random like that, but I was hoping to find something simpler for easy repetition.  And I would also like to keep the masts loose so they can be removed for easy storage, or to swap out the sails.  Any thoughts?
      Any resources, tips, recommendations are very welcome!  I'll post back here with any updates.
    • By MoonglowMinis
      Hi all.  Still relatively new to the forums but I'm going to try to show off my work more often.
      I was working on an arctic campaign before the pandemic hit and had already started work on a lot of suitable minis.  Not sure when or if that game will ever resume, but in the meantime I've got plenty of minis to paint!
      This time we have the Ice Troll.  I'm satisfied with this.  Especially proud of his ice chunk.  I've never been very successful painting ice or crystals before.
      Hope you enjoy!
    • By Orlando_the_Technicoloured
      https://www.kickstarter.com/projects/yetlblack/corvus-corax-miniatures-sons-of-yetl-black
      Story
      Corvus Corax Miniatures is a small hobby project created in 2013. Since then, four projects have successfully funded on Kickstarter and all have been fully delivered on time without any delays. The feedback from the backers have only been positive!
      The goal of this project is to raise funds for the production a total of four (4) miniatures for the Sons of Yetl Black. The miniatures will be cast in high quality, non-toxic resin. The scale of the miniatures is 35mm (measuring to the eyes in a standing, straight pose, although some characters may be slightly larger because they are supposed to be large characters).
      Strendu Bodaway Pachoa Niyol  (Actual copies of the resin miniatures. Note that the resin miniatures below are not 100% in scale with each other, but resized for editing purposes.)
        Grefven always makes lovely things and is a reliable KS creator
  • Who's Online   15 Members, 3 Anonymous, 40 Guests (See full list)
