Needed: Airbrush Equipment Basics and Recommendations
Girot
Wargame Consortium has a YouTube video of an hour plus presentation with the CEO of Badger which is really informative. Also certain brushes only work at specified PSI. Siphon bottom feed brushes are almost worthless below 20PSI. Most gravity feeds can shoot at 5PSI but the paint must be no thicker than ink.
The PSI paint thickness combo is one that ultimately must be learned by touch. I can say thin to the consistency of whole milk and blow at 15PSI with a gravity feed brush. In the long run you will discover on your own why that is worthless instruction to your situation. The reason I say this is each paint color behaves differently in your brush.
  • Replies 108
Can anyone suggest a really good guide/video/whatever for figuring out the proper pressure & paint thickness? Since I don't know anyone in RL with airbrushes, trying to figure out if I need to increase or decrease pressure based on what it is doing, or if I should be thinning more or less is something I'm finding a bit tricky.
There isn't a single good site I've seen, as it kind of differs by material. What I did when I first started, was practice thinning and spraying on a piece of paper. My best advice is to just hit YouTube and watch everything that seems even remotely relevant. In general you want your paint to have the consistency of 2% milk or lower, and then I use 15ish psi for small work, and 20-25 for larger pieces. I never go higher than 30. If I need that much paint, I'm probably priming, and I tend to just use an aerosol for that. Exception made for Bones. I don't prime Bones at all.
Thanks guys. I'll check out the Wargame Consortium video. I've watched a few others, and it all seems to make sense...right up until I've got the airbrush in my hand....
I'm using a Badger Patriot 105. I still need to get a a regulator for my workstation, right now I have to adjust the one on the outflow for the compressor. Airbrush supplies are really hard to find around here, and shipping for airbrush stuff in (and into) Canada is annoyingly high.
I was wondering what your guys opinion of the Patriot 105 is? Im getting started in airbrushing and plan to in the future expand into airbrushing automotive/motorcycle parts but until i get to that point i want something that i can use with my models. i have a no name double action siphon feed airbrush but i cant get fine lines out of it and i saw that the patriot is quite capable of that.
Thanks
Patriot 105 --> http://www.badgerairbrush.com/Patriot_105.asp
When i first started looking into airbrushing, the patriot 105 was pretty much the standard brush for mini painting as far as Badger products were concerned. However, the year I had my first class with Matthieu Fontaine at Adepticon, Badger had just released the Renegade Krome, and Matthieu was just starting to try it out, and was pleased with it. Badger had a booth and was selling the Krome at a great price so I bought one. It has been a great brush. It comes with a fine, and ultra fine tip/needle set up.
I just found this review:
https://sites.google.com/site/donsairbrushtips/badger-krome
Notice the doodle he does with it with an xacto blade for comparison. If it can do that, it should be able to do almost anything you need for our hobby.
I have a side siphon feed (1 of 3 brushes I own) and the problem still remains that you can't get the PSI as low as you will want. It still requires a bit of pressure.
Also like writing or painting you aren't sighting straight down your tool so the location of the cup is irrelevant.
Edited by psyberwolfe1
Thanks for all of the comments in this thread. I've been on the fence about getting an airbrush for a while now, the price point of most brushes and compressors at my flgs have stopped me from jumping in. The cheapest brush/compressor combo at my local store is about $500. After reading through this thread and seeing this: http://www.chicagoairbrushsupply.com/patasetwid3c.html
I've decided to take the plunge and get one.
Thanks for all of the advice and great discussion.
I just picked up the Paasche D3000R compressor with the 1 Gallon tank, and an Iwata HP-CS. The compressor is great and very quiet, about the same volume as a normal conversation. I live in a condo and need something that won't piss off the neightbors when I run it at night. It only needs a couple minutes to fill, and then auto shuts off again.
I'm very happy with both devices. I did have a problem with the pressure guage on the regulator, but the folks at Paasche were great about quickly shipping a new model to replacing it. I was actually so happy with their service, I'm looking at picking up a talon as my secondary brush.
With a Sparmax GP-35 brand new airbrush, I got stutter of paint right with Scale75 black primer (that is supposed to work great as-is for airbrushing) dilluted with water, about 50/50.
I experienced some better results with a dilution ratio of about 75/25 primer-water, plus a droplet of Vallejo Acrylic Thinner. I don't really know what is in that thing...
I have a cheap chinese compressor, no water trap, unknown output pressure. What are the main things to cause uneven pattern, stutter and splotches in a brand-new, clean AB?
Well the wife told me to be on the look out for a decent airbrush for the kids to get me for my birthday.  So after I dropped off eldest spawn and her friend at the mall, I swung by AC Moore.  After finding out that the 50% off coupon was indeed valid on airbrushing equipment, I came home with a Badger Renegade Krome.  No I just need to get all of the components to connect it to my existing compressor.  So that should be a regulator and moisture trap and hose.
Looking forward to getting to play with it.  Only problem is that I have to wait a week until my kids give it to me.
I would look to see if you can find a pressure regulator to put inline in your hose so that you know what pressure you are using.  I think most people tend to use about 20 PSI on their compressor.  Perhaps more if you're having problems.
I'd also see about getting a water trap near the end of the hose where the air brush is.  You're not going to like water from the compressor getting into the airbrush.  The results will be bad and it's going to happen!  The one I use is from iwata and screws in right at the base of the airbrush and gives it more of a pistol grip feel.  I find it more comfortable that way.  But not sure if it would work with your air brush.  I've also seen hoses with an inline water trap near the airbrush end as well.
And I believe the Vallejo thinner is designed to thin out the paint without diluting it like water would.  Keeps the "chemistry" of the paint more like it is originally but makes it thinner.  I'll let someone with more experience speak to that here!  I know many use just water.   Or even a mix of water and alcohol.
Edited by Harrek
    • By Reaper_Jon
      Reaper Challenge League 2022
      1) Intro
      2) How It Works
      3) Types of Challenges
      4) The Raffle
                         PDF Check List               Discord
      Intro:
             Welcome to the Reaper Challenge League (RCL), a system that rewards fans for completing community-based events and challenges. This will all be conducted via the Reaper Miniatures Discord, where there is a system in place to track points and administer raffles easily (see below).
      THIS IS NOT A CONTEST ----- This is meant to be a challenge against yourself to see what you can accomplish, not a contest to compete in against other people in the community. So enjoy your time in creating stuff and have fun doing it with everyone else!
      Only Reaper minis will be accepted except for in the Freebie/Bust categories. You can use any paints for submissions, the only exception is the Limited Palette challenge.
      How It Works:
      Users can submit photos of RCL projects on the #submissions area on Discord and receive points depending on the tier of challenge.
      These points can then in turn be used to purchase raffle tickets which will be drawn quarterly, with a large annual raffle at the end of the year. Only Reaper minis will be accepted for submissions, except for in the Freebie/Bust categories. You can use any paints for submissions, the only exception is the Limited Palette challenge. Each quarter, a RCL raffle shall be held during the last seven days. This ensures that people have ample time to enter tickets or finish any entries so your points may be exchanged into tickets. On the last day of the quarter, the raffle will be drawn, and winners posted. At the end of the year a larger raffle will occur that accounts all accrued points points you have earned yearly (spent and unspent).  Terms and Conditions may change at the discretion of Reaper Miniatures at any time.
      Type of Challenges:
         All entries must show some sign of trying and not just throwing paint on to get some quick points. In keeping of the spirit of the league, challenge yourself and see what you and others are capable of. The amount of points that each one challenge will grant are in the () below, as well on the PDF for the 2021 chart. Reaper Challenge League PDF
      The Raffle:
           The raffle will happen the last 7 days of each quarter, This will ensure that people have ample time to enter their tickets or finish any entries they need to complete before drawings. Tickets will be pulled on the last day of each quarter!
          This will all be done on the Discord server, as we have a bot that is programmed to keep track of members points and how many tickets they have. We will use this bot to open the drawing and for you to enter and participate with the system. The drawing will stay open for one week before doing the drawing on the last day at a set time!
      Thank you, the team!
      Frequently asked questions
      Q: I am just wondering if one model can be turned in for two different categories?
      A: In the spirit of the challenge, we would like it if you submitted a different model for another challenge. As this isn't a contest and meant to get people hobbying. 🙂 so you would just be doing yourself a dissatisfaction!!!!!
      Q:  Since the Reaper Discord moves so insanely fast, how will winners be notified?
      A:There will be a channel that is static that is read only, for raffle winner and other announcements.
      Q: Will the raffle draws be things that can survive through colder climates when shipped?
      A: Not to sure on the exact prizes but this ties into your third question, I can hold things for you if cold climate is an issue and ship it at an opportune time.
      Q: For the Quarterly holiday - what are you looking for for Q1?  Like would just, any winter/snowy model be ok, or do I need to figure out what a MLK day themed model would be? 😜
      A: The rules are very loose, as this is not a contest and is meant for you and others to hobby!!!!!! So if you think its a holiday or a special day? By all means paint something and present it under that challenge category, as long as you spent time and effort into making it, I will recognize it. As an example if you wanted to paint something that was for your birthday! i'll count that!
      RCL 2021 udated list! - Sheet1.pdf
    • By Pancakeonions
      I am stunned at my recently arrived Sophie's Revenge, and so excited to get it to the painting table (I will have to significantly reconfigure my painting space to ensure I have enough room...  As well as buy LOTS of new brown paint, ha!)  It is a thing of beauty, even without a lick of paint on it.
      One of the first things I noticed was how the magnetized masts SNAP to the deck, hard.  That's what you want, so they'll stay firmly in place.  But when you remove 'em, they'll likely scratch the heck out of the painted deck.  So I plan to cut disks of black felt to glue to the underside/ magnet-side of the masts, so that when they stick, they're more gentle.  Thin felt should not affect how they stick, but it should make a big difference on the ship's wear and tear.
      Are you planning on painting yours?  What strategies are you going to adopt to make it as beautiful as you can, while still keeping it sturdy as a plaything for your RPGs, wargames, or maybe even little kids (don't judge!  mine are gonna be all over this thing!)
    • By insaniak
      StackaRack is a customisable plastic rack for miniature paints, designed to hold pots or bottles from any of the major manufacturers.
      Paint collections have a way of growing organically, and most of the current paint rack solutions out there are fixed to specific configurations, and made for a specific type of paint pot. If you're like me, and collect multiple brands of paint, that can make organising them a little frustrating, and so we thought we would try to fix that.
      StackaRack was designed to hold any of the major miniature paint ranges - from the dropper bottles used by Vallejo and Army Painter, to the tall pots from the likes of Privateer and Reaper (and GW's old range), and the current stubby Citadel pots. The injection moulded plastic parts will fit together with plastic clips, allowing you to build it how you like, and disassemble and reconfigure it as needed.
      Check out the project live on Kickstarter here: https://www.kickstarter.com/projects/spiralarmstudios/stackarack?ref=acpi8t
    • By R2ED
      Having recently joined the airbrush crowd, I'm discovering how much i love blasting paint through it.  Saving so so so so much time on my zenithal priming groups of minis.
      Now that I've got the priming and ink through it, I'm curious about another medium going through - varnish.
      I own satin and gloss varnish from liquitex. I've used them as brush on, which isn't my favorite.  I want to know:
      1.  Has anyone used this in an airbrush?
      2.  If yes, how did you thin it?  Did you use airbrush thinner or something else?
      3.  Does it require different means to clean after using?
      I'm super paranoid about clogging or ruining this new tool of mine.  I found out Stynylrez primer wasn't just pour in and go.  Made for a fun clean up with my first go at priming.
      There's a ton of stuff I'm seeing on testors dullcote from the bottle and mixing it with their thinner, but I'm hoping to use what i have if it's possible.
      I'm not asking what you use as much as I'm seeking specifically "has anyone used liquitex varnish in their airbrush? "
      And... any pictures of your results?
    • By SparrowMarie
      I'd never felt I had an artistic bone in my body until I started painting minis. Well, now, I decided I'm going to try my hand at 2D art.
      I am following along Bob Ross videos on YouTube. I will note, and this is probably very important, that I am using acrylic paint and not oils. I did not want to spend oil paint prices since this is a new thing for me.
      These are the two I've done:
      Day 1: I learned a lot, I needed to do something with my paint to extend the drying time. This would have helped with the blending. Overall, happy with it excepting the house.
      2: I used some slow dry medium mixed into the paint today. Not sure if it was not mixed well enough or I didn't use enough but it only gave me like 5 minutes or less of extra working time. If anyone has any suggestions for how to use slow dry medium, please, let me know. I'm using heavy bodied acrylic tube paints.
      I followed along until the end and I decided to add some darker blue and green. I think that helped a lot.
      Another note, need to find sturdier paper. While this is holding up it likes to curl slightly while drying. The second one is taped to the desk on the back to try to minimize that problem. I am currently using a mixed media paper.
