[Group/Open] WIP Kaladrax
  • Replies 23
Yeah, but the plus is that it'll act as a think-tank to work out bugs or solve issues. One WIP on its own would reveal a lot of them, if they're common, but having multiple Kaladraxes in one place means if SamuraiJack finds one issue, and then I find a different issue, and somebody else finds another anomaly, then it covers the gamut.
I don't expect Kally to have too many issues, but he's fresh to the mass market and you never know what might come up.
Is the scenic base one solid chunk of bonesium or is it hollow? I am planning on using one of the LED kits from Powered Play Gaming's recent Kickstarter and would like to know whether I need to plan on hollowing it out for the controller board and battery. Thanks!
I don't think you can reverse the rear legs - the hips can be swapped, but then the feet point the wrong way. It's a bit of an odd position, but he has two feet tabbed into the base and his belly rests on the base too. I don't think he'll go anywhere once glued.
Showdown!
Edited by trystangst
  • Like 10
    • By Metalchaos
      As you continue exploring the cathacomb, you catch sight of a ghastly humanoid creature walk in your direction. The stench of death and rot lingered around its undead forms. You recognize with horror, a minion of the dark necromancer queen Kiaransalee. This is a 77159, Ghast sculpted by James Van Schaik.
    • By Iridil
      I've bought several Christmas minis over the years, but this is the first one I painted! He's such a cute fellow and I had fun with him, even if it was Dec 28th before he was done...
    • By Iridil
      Well, finally painted him - and I'm pretty satisfied. I heavily borrowed/copied from this post: https://forum.reapermini.com/index.php?/topic/84520-77594-solar-angel/#comment-1788530,
      It went better than I expected.
    • By Grim
      I may end up doing a bunch of image dumps - I've painted a lot this year and maybe I should just post them in sets.
      This one, though, deserves its own post, I think.  I painted up the Green Dragon Hatchling from waaaay back in Bones 2, showed it to my wife, and she made some suggestions - so here you have it painted up as a Swamp Dragon from the Discworld, as kept by Lady Sybil of Ankh-Morpork.  I gave them a collar and name plate, and since they're a tame dragon, I gave them a few chew toys, including a Rolly Ball just like Rex of "Snake Discovery," as can be seen here:
      https://www.twitch.tv/snakediscovery
      Comments, criticisms, and suggestions welcome!
    • By SotF
      I actually painted this shortly before the lockdowns started when the store had it and the D&D campaign I was in was running Lost Mines and we'd gotten to the beginning of the dragon encounter. So I'd painted it up and brought it in since the DM didn't have a green dragon of the right size and the sculpt actually looks a lot like the D&D Green Dragon if you remove the tail blades.
      After running it, another friend wanted to borrow the mini for an adventure he was running right as lockdown started and I just got it back.
      The big thing with it was the expirament with various stick on plastic jewels and if I could use gold and silver glitter with a large enough size to work for coins as a a workable basing material with some added wash ontop. I like the result there and it gives the feel of the dragons hoard that it might have been napping on when someone woke it up.
