daveismyhero
Reaper paints - To thin or not to thin?
Hello all,
Brand new painter here, getting ready to start painting my first Bones with my son. I'll be using paint from the LTPKs and the Kickstarter.
Should I thin the paints before using them?
Thanks in advance for taking the time to share your opinion and/or for firing some helpful links my way. ::D:
Dave
yes and no, Bones Do Not Take Well to thinned paints, Now after you get your base coat on you should get in the habit of thinning your highlights as it makes controlling the paint a bit easier imo.
For basecoating Bones, not really. Shake them, shake them some more, roll them back and forth to each other across the floor (my daughter and I have shaken paints this way) and then give them another good shake. If you find the paint is going on a bit blobby, thin it a little at a time till you get it to play nice. Be patient with the paint, learn how it acts, Reaper paint is very good but all paint has a mind of its own.
Reaper's site has a some articles on thinning your paints; you should ignore those for now!
Depends on the task at hand. If applying a base coat to Bones, no. Also most base coats don't need thinning. Almost everything else you do does though. If using MSPs, just use water to thin them. Other additives are not typically needed.
See this article, Let it Flow, but you can ignore the parts about aditives like Magic Wash. The article was written before MSPs came out. Otherwise it is spot on.
Andy
Yeah, I always thin a bit after the basecoat on Bones. A lot of colours won't give you the results you want in one coat, so you want to be able to go over them once or twice without building up a thick gunky coat of paint.
Thanks very much for the tips and link. I appreciate it!
I finally got the chance to play around with my paint, and some of them were definitely on the thinner side (mostly greens).
    • By Werkrobotwerk
      Does anyone know what the closest match to dirty grey is out of the currently available paints? I'm kind of on my last little bit of it, and I used it on a bunch of stuff that I'll likely need to get close to matching in the future.
    • By SparrowMarie
      So my niece is turning 13 next month. She already has a huge interest in minis and loves to paint with me. I'm trying to build her a kit or care package for her birthday so we can video chat and paint together. I'm at a loss as to what to put in it though. She has a ton of minis I gave her and a few brushes but I want to get her like a full starters kit of sorts (paint, better brushes, brush soap, etc.). I'm already considering the first LTPK. What would you put in it for someone just starting out?
    • By SamuraiJack
      Some of these came back as other numbers, but but the rest won't be brought back by Reaper and some might be present in other paint lines.
      (Twilight Triad 9727)
      9079 Deep Amethyst
      9080 Indigo Sky
      9081 Pale Indigo - mix equal portions of Imperial Purple and Sky Blue
      (Colored Liners Triad 9738)
      9112 Red Liner - Reaper 9235 (Back in Bones 3 as 9307)
      9113 Green Liner - Reaper 9236 (Back in Bones 3 as 9308)
      9114 Violet Liner - Reaper 9237
      (Muted Purples Triad 9740)
      9118 Dusky Grape
      9119 Bruise Purple
      9120 Faded Purple
      (Clear Brights III Triad 9744)
      9130 Clear Orange - Lava Orange 9218 and Explosion Orange 9219
      9131 Clear Viridian - Peacock Green 9226
      9132 Clear Plum - Royal Purple 9240
      (Blush Colors Triad 9747)
      9139 Antique Rose - KS Old West Rose
      9140 Blushing Rose
      9141 Porcelain Rose
      (Historic Blues Triad 9751)
      9151 Steely Blue
      9152 Military Blue - Reaper 9269
      9153 Weathered Blue
      (Desert Camos Triad 9752)
      9154 Dune Shadow
      9155 Desert Khaki
      9156 Desert Sand
      (Mist Greens Triad 9756)
      9166 Shadow Green - Reaper 9270
      9167 Field Green
      9168 Mist Green
      (Terracotta Clays Triad 9757) - Redstone Triad 9775
      9169 Muddy Clay
      9170 Terracotta Clay
      9171 Fired Clay
      (Cold Greys Triad 9758)
      9172 Stormcover Grey
      9173 Coldstone Grey
      9174 Icy Grey - KS Aircraft Grey (slightly greener)
      (Volcano Browns Triad 9760)
      9178 Cinder Brown
      9179 Volcano Brown - Reaper 9268
      9180 Ashen Brown - MSP HD 29831
      (Tropical Colors Triad 9761)
      9181 Bright Coral
      9182 Saffron sunset - Reaper 9247
      9183 Cloud Pink - KS Reaper Punk rock Pink
      (Reptilian Greens Triad 9762)
      9184 Serpentine Shadow
      9185 Reptus Green
      9186 Scaly Highlight
      (Sandy Colors Triad 9764)
      9190 Sandy Brown - Reaper 9249
      9191 Sandy Tan
      9192  Sandy Yellow
      (Sea Blues Triad 9765)
      9193 Stormy Sea
      9194 Clouded Sea
      9195 Seafoam Blue
      (Humanoid Skintones Triad 9768)
      9202 Troll Shadow - MSP Stained Olive 29838
      9203 Gnoll Brown
      9204 Halforc Highlight
      (Reaper Ink II Triad 9771)
      9211 Green Ink
      9212 Blue Ink
      9213 Purple Ink
      (Spring Greens Triad 9749)
      9145 Moth Green - Reaper 9248
      9146 Spring green - Reappaearance at RCon 2015
      9147 Luminous Green - Reaper 9248 + 1 drop of white
      (Heavy Gear paints)
      RPR 61101 Terra Nova Tundra (Possible alternative: NMM gold?)
      RPR 61102 Macallen Brown
      RPR 61103 Redrider Crimson
      RPR 61104 Dune Shadow
      RPR 61105 Mekong Moss
      RPR 61106 Giant Fern
      RPR 61107 Okavango Swamp
      RPR 61108 Republique Red
      RPR 61109 Armadillo Tusk (hd)
      RPR 61110 White Sand
      RPR 61111 Paxton Red
      RPR 61112 War Paint Red
      RPR 61113 Arthurian Blue (hd)
      RPR 61114 Blue Crescent
      RPR 61115 Atlantean Aqua
      RPR 61116 Coated Armor
      RPR 61117 Factory White (Ghost white + Blue Flame perhaps?)
      RPR 61118 Grel Flesh
      RPR 61119 Afterburn Grey
      RPR 61120 Hazard Yellow (hd)
      RPR 61121 R.a.m. Black (hd)
      RPR 61122 Durasheet Alloy
      RPR 61123 Skunkworks Gunmetal
      RPR 61124 Beacon Yellow
      RPR 61125 Fallout Grey (hd)
      RPR 61126 Ash Grey
      RPR 61127 Waveform Aquamarine
      RPR 61128 Gamma Shielding Gold
      RPR 61129 Cat's Eye Umber (hd)
      RPR 61130 Cat's Eye
      RPR 61131 Red Dust
      RPR 61132 Drillbit Metal
      HD Line:
      29803    HD Entrail Pink
      29804    HD Rusty Red
      29805    HD Burning Orange
      29807    HD Mustard Yellow
      29810    HD Mossy Green
      29814    HD Ice Blue
      29816    HD Solid Blue
      29817    HD Winter Blue
      29818    HD Nightsky Blue
      29821    HD Sunburn Flesh
      29823    HD Caucasian Flesh
      29824    HD Maiden Flesh
      29829    HD Golden Brown
      29830    HD Ruddy Brown
      29831    HD Ashen Brown
      29832    HD Concrete Grey
      29833    HD Ash Grey
      29834    HD Field Grey
      29835    HD Dirty Grey
      29836    HD Military Grey
      29837    HD Armor Grey
      29838    HD Stained Olive
      29839    HD Maroon Red
      29840    HD Garnet Red
      29845    HD Gilded Yellow
      29846    HD spruce Green
      29847    HD Rich Indigo
      29848    HD Jungle Camo
      29849    HD Umber Brown
      29850    HD Elfin Flesh
      29851    HD Tropical Aqua
      29852    HD Dwarven Flesh
      29853    HD Rosy Pink
      29854    HD Arctic Grey
    • By Ekaterina
      Hi!! my name is Katerina and I'm new to painting miniatures, I begun
      with a miniature from NonSenseminiatures, the Barbarian, I buyed the
      54mm because it's bigger and maybe easier to paint.
      I asked some help to NonSense and he already made a base coat for me, I
      would like to get some help for painting because I see too much
      information and don't know were begin.
      I already make painting but totally different
      Also he gave for me a discount code Katerina10%, because he will sell my
      paints also!!!
    • By Al Capwn
      I don't have a blog, and I am not veteran or post enough content to justify making one - so while these musings may be better served in that format, I will leave it here for anyone who is interested to view and chime in. It just so happens that my best friend happens to work at Rustoleum as a colorist; so lately I have been picking his brain since he has an extensive knowledge about pigments, paint make up, and the chemical intricacies therein.
      As I have delved further and further into the hobby, I have been looking more into the deep subjects of color theory and how paint is made/composed. After reading James Gurney's Color and Light, as well as Michael Wilcox's Blue & Yellow Don't Make Green, I was really intrigued about what exactly paint is and how exactly color interactions work. Now I am guilty as the next person in owning WAY too many paints - not to say anything about minis!
      While color mixing may seem irrelevant to some, understanding how paints function can help even those of us who own a complete gamut of convenience mixed colors. This post is about exploring more of the technical and "scientific" aspects of paint and color theory to hopefully assist others in understanding the what and why of paint.
      Rethinking Paint Colors - Subtractive Color:
      Up until recently, I have always viewed the primary colors as Yellow, Red and Blue, and with those you can mix secondary colors; Green, Orange, and Purple. While this is technically true after a fashion, the difficulty lies with pigments themselves. Pigments do not actually *contain* color. Instead, they absorb most of the light spectrum *except* a specific wavelength of color. As Michael Wilcox states, "Of all the pigments available to the painter, none can be described as pure in hue. There is simply no such thing as a pure red, yellow or blue paint." That means chemically, there isn't a paint pigment out there that returns a pure Red - unlike in say digital art where a specifically purely calibrated hue can be made, paint is limited by the properties of the physical pigments themselves.
      As Michael Wilcox theorizes with a colour bias wheel (bottom-right), primary pigments almost certainly lean towards secondaries. This follows the concept of the Munsell Wheel (bottom-left). You may have heard of a split-complimentary color palette, and this is the reason why. Artistically, these have been described as "Warm" and "Cool" versions of the primaries, but scientifically, they are colors that absorb or reflect more of a particular wavelength. There are Violet-Reds (Cool Reds, often called "Crimson") and Orange-Reds (or Warm Reds, that lean more towards Orange), Violet-Blues and Green-Blues, and Orange-Yellows and Green-Yellows.
      One the concepts to understand when mixing paints is that you are not creating a color, but rather you are effectively destroying colors and what remains is what is returned to the eye. Referencing the above color bias wheel, if you were to mix a Violet-Blue and a Violet-Red together, both containing pigment(s) that return a great deal of Violet wavelength, the little remaining Blue/Orange and Red/Green wavelengths in each pigment would cancel each other out, leaving the Violet behind.  This would yield a more saturated or more pure hue of Violet. Conversely, mixing a Green-Blue and a Orange-Red ("Warm" Red) would be a very desaturated Violet, with more of a gray tone.
      Keep in mind that this doesn't make a color "bad"; desatured tones by including more complimentary colors is a very useful tool! In fact, for making shadows, using a great deal of complimentary colors to desaturate is a great technique. The problem is when these colors come about unexpectedly; after all, you can have a very "intense" Red and a very "intense" Blue, but mixing them may not produce a very intense Violet if they are "moving away" from each other.
      Now that is all being said, it is time to forget it...sort of. RGB is based upon the concept of Additive Mixing, or how colored light interacts. With additive mixing, fully saturated Red/Green/Blue light will produce White light. However, in paint pigments, it should be pretty obvious that mixing pigment primaries of Red/Yellow (or Green)/Blue together will not yield White. This is due to Subtractive Mixing, where pigments effectively destroy each other ala Thunderdome in Mad Max, and only the survivors reflect light back.
      A more modern approach to color theory and pigments is CMYK or Cyan, Magenta, Yellow and "Key" (or commonly known, Black). Adding these colors into the standard primaries gives us the "Yurmby" wheel. If you have looked at a color printer, for example, the colors used are NOT Blue/Red/Yellow, but rather Cyan/Magenta/Yellow. This is because due to the subtractive nature of pigment/ink mixing. These colors present a larger printable gamut (i.e. range) of color; for example, without White, it is difficult to produce a Pink tone with Red vs Magenta. A thin Magenta will read more Pink than a thin Red.
      Printers do not use White ink and instead leverage the paper for white, effectively printers are printing in an underpainting style. However, we as artists DO use White pigments and this makes things a bit more complicated as we do work with Tints (White) and Shades (Black).
      Like most science, the direct answer regarding an accurate color wheel is: it is complicated. For observable light, there is a bit more consistency and repeatability. However, when working with "tiny wavelength absorbing/reflecting mirrors" of pigments, things become a bit more complex. Additionally, there are other aspects that that go beyond the basics, such as the effect of specular and perception of color. It gets really heady when you start dipping into Kubelka-Monk Theory and K/S.
      Paint Composition:
      Most paint is made up of 3 parts:
      Pigment - particles that absorb and reflect certain wavelengths of light.
      Binder - The 'medium' or 'glue' which holds the pigment in suspension and forms a film. For acrylic paint, this is the actual acrylic part.
      Solvent - The liquid that allows paint to be viscous; as it dries, it allows the binder and pigment to harden forming the film. For acrylic paint, the solvent is water.
      Adjusting the ratios of these can have some interesting, and sometimes disastrous effects in terms of the stability of the paint. For example, introducing too much solvent, and the binder and pigment lattice structure can break apart. This can cause "coffee staining" or splotchy spots where the bonds pull apart, leaving areas without a film at all.
      The pigments in paint are held in a suspension. Like hot chocolate mix, there are tiny particles that are suspended in a liquid. Given enough time or evaporation, the liquid will leave these granules behind. If you have ever mixed a packet of Swiss Miss cocoa, you know that the mix can settle at the bottom - and that attempting to add dry powder to a liquid is more difficult than adding a liquid to a dry powder. This is another reason why mixing your paints is important because it is easy for the heavier pigments to tend to settle out of the binder/solvent solution.
      Speaking of solutions, that is the main difference between paints and inks. Inks, specifically alcohol inks that use dyes, are a solution. The staining dye actually becomes homogeneous with the liquid. Just like dissolving sugar or extracting coffee/tea, there isn't any particulates that separate out. However, most dyes are not lightfast - a property that will be discussed in more detail further. Acrylic inks that use pigments are not "true" inks insomuch as they are composed just like an acrylic paint. The difference being the smaller size of the pigments and the viscosity of the binder/solvent being much thinner.
      Paint Additives
      Outside of the 3 main components for paint composition, there are also some optional additives that some manufacturer's include in their paint. These can be things such as:
      Extenders/retarders, which delay the setup of the paint film, allowing for more mixing to occur before drying. Thinners, which dilute the pigment to binder ratio, usually increasing translucency and viscosity - commonly this is done with water for acrylic paints. Flow Aid, which reduces the surface tension of paint, allowing it to flow more easily and level - Reaper is known for adding a bit of flow aid into their formulation. Opacifiers, which increase the opacity of a paint - usually some type of calcium or bicarbonate. Matting agents, which reduces the glossiness of acrylic medium. Fillers, which are commonly used in student or inexpensive paints to reduce cost and add mass without adding more pigment.
      You can add some of these additives yourself to your favorite brand of paint to adjust the handling qualities. The most commonly added is solvent/thinner in the form of water to "thin your paints" to reduce the viscosity and lower the overall density of the paint, building up multiple thinner layers of paint films in a "layering" fashion.
  • Who's Online   17 Members, 3 Anonymous, 43 Guests (See full list)
