Nanite Posted January 10, 2014 Share Posted January 10, 2014 I've got a Nikon Coolpix S6300. I'm having isues with Macro mode. It seems like the more light I put on a mini, the darker the resulting picture. Is this an ISO problem? Anyone have this camera? Hopefully it's something I'm doing wrong. Quote Link to comment Share on other sites More sharing options...
Doug Sundseth Posted January 10, 2014 Share Posted January 10, 2014 Are you using a white background or a light box or both? Quote Link to comment Share on other sites More sharing options...
cmorse Posted January 10, 2014 Share Posted January 10, 2014 Sounds like a white or light colored background confusing the camera's light meter. Try either a more neutral background or switching to spot metering (only uses the center of the picture to judge the light). Quote Link to comment Share on other sites More sharing options...
Mistimp Posted January 10, 2014 Share Posted January 10, 2014 Skip the macro mode. Get a tripod and a remote shutter release (self-timer will work if your camera does not have a remote. Place the camera well back from the mini, with a decent depth of field. Use normal room light and a 3-6 second exposure. Then crop the pic to remove all the excess background. You will get a much better picture. Quote Link to comment Share on other sites More sharing options...
Mistimp Posted January 10, 2014 Share Posted January 10, 2014 Forgot linky http://massivevoodoo.blogspot.com/2013/09/miniature-photography-part-2-how-do-i.html?m=1 Quote Link to comment Share on other sites More sharing options...
CashWiley Posted January 10, 2014 Share Posted January 10, 2014 With my old compact camera, macro mode helped it focus on the mini instead of the background. With the SLR, I just use normal modes. Quote Link to comment Share on other sites More sharing options...
Doug Sundseth Posted January 10, 2014 Share Posted January 10, 2014 Are you using a white background or a light box or both? Didn't have time last night, but here's why I asked: You said that the "picture" is getting darker as you increase the light, which I suspect means that the exposure of the subject is reducing as you increase the light. Digital cameras set automatic exposure based on the average lighting in a scene (in most exposure modes). 1) With a white background, the average of the entire field will be very white, which means that the non-white parts (the miniature) will be dark. If you want to keep a white background, you'll need to use positive exposure compensation. 2) Most light boxes put light on the top and sides of a miniature and not so much on the front. When photographing miniatures, you want the front (side toward the camera) well lit. When you add light to the outside of the box, everything but the front of the miniature gets brighter, so the front gets relatively darker (it's primarily lit by the lights in the rest of the room). 3) If you're doing both, the problems are exacerbated. Suggestions: 1) Ditch the light box. They're very useful for taking photos of new cell phones, or gold rings, or whatever. Unless you know exactly what you're doing, they are actively harmful for miniatures photography. 2) Use positive exposure compensation if you have a light background and negative exposure compensation if you have a dark background. If you're not comfortable figuring out exposure compensation, use a lightish gray background. 3) Use desk lamps (or whatever you can aim easily) to put light on the front of the figure. 3 Quote Link to comment Share on other sites More sharing options...
Nanite Posted January 12, 2014 Author Share Posted January 12, 2014 (edited) Huge thanks guys. Ditched the lightbox and white background, lit from the front. Result: massive improvement. I forgot I had the ISO setting turned way up, sorry for the graininess. Edited January 12, 2014 by Nanite Quote Link to comment Share on other sites More sharing options...
