shibe
Help with Varnishing my first mini
Hello All,
This is my first post so please excuse any incorrect use of etiquette here.  I hope this hasn't been posted elsewhere.  I have searched for varnishing tips and I get conflicting information all over the net.  Each person has their own methods and what works for them it seems.
I have a pewter mini I purchased through Reaper. (Lucius Panderwagon)  It is my first one.  I have just about finished painting it and I purchased some varnish to complete it.  I have Liquitex Matte Varnish.  The liquid inside looks cloudy and when I test paint it on a surface it gives it a light frosting.  Should I be using this as a varnish?  Does anyone have any better suggestions for this?
Just want to say thanks in advance for all the contributions on this forum.  All the information has been very helpful in getting my first project going.  Lots of fun.
first of all, welcome to the forums. I've never used liquitex varnish before, so I can't help you out there, but someone should be along shortly who can.
Hey welcome to the forums, I've not done the varnishing thing either, but I think what you'll probably want to look up is "dip," "dipping," or "quick dip." There are products out there like Quick Shade from Army Painter. Here's a video on how it's done. Other people use Minwax, there are plenty of different shades for Minwax and Army Painter has 3 different shades.
Hope this helps!
Are you just trying to put a protective top coat on the miniature, or use the varnish as a shade medium? If you are just trying to create a protective top coat, I'd suggest either Testors Dullcote or Reaper make a brush on sealer that I've not used but many people swear by.
EDIT: Added link
Edited by The Inner Geek
I brush on varnish.  Not with the expensive liquitex stuff, mind you, but I'm pretty sure the premise is the same.  That frosted look you've described commonly happens when applying too much varnish.  It looks like the liquitex stuff is water-based, so you can thin it out a bit with a couple drops of water before you apply it, and make sure you also apply it in thin layers, and use your brush to prevent it from pooling too much in the low spots on the mini.  Multiple thin layers are better than a single thick one.
Many claim that for protection, gloss varnish is sturdier than matte varnish, so a common process is to do a first coat of gloss varnish, followed by a  second coat of matte varnish.
If all you have is the matte, it will still protect your paintjob though, just maybe not as well as the gloss/matte 1-2 punch would.
Edit:  Oh!  I forgot to mention.  I've also heard of spray varnishes causing frosting if applied in too cold a temperature.  Unsure if this also applies to brush on varnishing, but it's something to be aware of, anyways.
Edited by Sabith
Yeah, I use the Testors Spray to seal my figures as well, it's the matte stuff, but I do have gloss now too. Also in my arsenal is the reaper brush-on sealer that I use for all sorts of things, but that is also glossy so I make sure to always hit it with the matte sealant after the figure is done to tone it down unless I need something shiny looking.
To seal your figures with the stuff you have, water it down and brush lightly. In general, many painters choose testors dull coat and spray a light coat of it on their finished piece after shaking the can very well but what you have will work just fine too.
Hi!  Thank you all for the quick replies.  I mean to protect my paint job with a final coat of varnish.  I am just not sure if I am using the correct material.  I do not want it to be super shiny yet I also do not want a frosted look either.  I put a pretty thin coat of this stuff on a clear bottle so I could see how clear it actually dries.  I am not sure which way to go here.  I may go with something in-between the gloss and matte.  I hear satin is the one for that.  Does anyone have any experience with this particular brand?  How about any brands and methods that work best for them.  I hear a spray from a good distance is good as well as very thin coats with a brush of a non spray varnish. I will check out the videos as well.  Thanks for all the responses!
Edited by shibe
I will try to water it down a bit.  Maybe a gloss would look nice as well.  I can add a picture and maybe you guys can tell me what you think a good protectant would be for the way it looks? :)
Edited by shibe
Definitely try watering it down like cutebutpsycho says. Take pics and post them up. Put it up in the Show Off section of the thread since it's a finished product, if it's a work in progress then you put up pics in a WIP thread. This is a very friendly forum/community and really willing to give you good advice.
If you varnish it with the varnish you have (I'd definately take the thinning advice) and then decide it is too shiny for your tastes, you can re-varnish it with T Dullcote and it will take the shine away.
Edited by TaleSpinner
The way a matte varnish works is to scatter the light that reflects off of the figure to remove specular highlights (direct reflections off of the surface). If you put matte varnish on a clear bottle, it's going to look cloudy because of that effect. Part of the reason that you're having difficulty interpreting the replies is that it is possible for a dulling coat to frost enough that it will show up as a frosted coat over colors as well.
To see whether the product will give you the look you want, you need to paint a coat over something that is opaque and ideally multi-colored. (A piece of discarded packaging from something purchased recently should work fairly well.) A thin coat shouldn't obscure the details but should kill the shine.
    • By Arydis
      The goal is to make a miniature's shield look almost like a cracked crystal portal (to a galaxy).  My thought to achieve this is to create an illusion of depth with an underpainting, MANY layers of varnish, and even small touches of paint between layers.  Being a mini, there won't be too much bulk, but I wondered if anyone had any experience with a project like this and could offer any pointers.  Would this idea work?
    • By Pingo
      I'm planning to test some different ways of varnishing Bones, since there is some confusion and some materials seem to dry sticky, or turn sticky after some time.
      This is going to be a long-term experiment because of the aforementioned change over time.
      I have a dozen rats and five mummies from the first two Bones Kickstarters which I have painted up in colors known for their shininess (the blacks and reds on the rats) and their matte qualities (the grey bases and the linen color on the mummies).
      These are super quick paints, just there to test the results.
      Once they are fully cured I plan to number them under their bases and experiment with different combinations of matte and gloss finish, including at least one unvarnished of each type.
      I plan to report back after some time has passed.
    • By Splurch
      I seal my miniatures with Liquitex High Gloss Varnish through an airbrush and then do a matte coat. Last year, I put a number of figures away sealed with gloss but did not get around to putting a matte coat on them. Figures were primed with Badger Stynylrez, had several paint brands used on them and washed with an ink/liquitex medium/flow improver/slow dri home made mix. Some of these figures were Reaper Bones, some were not. They were all kept in a display case that, while not airproof, does keep dust out and is not in direct sunlight. The metal, resin and hard plastic figures have cured just fine and are not sticky at all. Even the bases of the bones figures, which are green stuff or plastic are not sticky. Only the bones figures themselves have become tacky. Some are barely sticky, some are so sticky I can press my finger to them and life the figure up without fear of it falling. I don't know when the problem happened, but the figures were sealed at various points last year and some had no issues for at least weeks after being sealed. Other bones painted at the time that were not sealed do not have this issue.
      The problem seems to be some kind of reaction with the bones material and the liquitex high gloss varnish that happens through the primer/paint. I've only read up on issues with them becoming tacky when aerosols that react with the bones material. I'm concerned if I matte them, the tackyness will just come through again. I had some issues with the same problem with Liquitex High Gloss and bones a few years ago when I started using it. After some change in application/use I eventually got it to work without issue (or at least with no immediate issue.)
      Has anyone else experienced your bones becoming tacky months after being sealed with no issues beforehand? Any idea why it is happening or if there is something I can do to fix and/or prevent it?
    • By knarthex
      Hey folks!
      A newcomer to the forums just made a comment that they did not know what Dullcote was, so after explaining what it was and adding a pic of the can, I thought I would add a link to a discussion on sealers....
      Imagine my surprise when I searched the pinned resources to find nothing listed!
      Now a search of this forum gave me many hits to a lot of different threads, but they were all about a problem, or people asking questions or something other.
      So I decided to start a thread talking about Sealers.
      Now I use Dullcote Spray Lacquer from Testors, and have been using it for over 30 years.
      I am not liable to change any time soon...
      I like the nice flat coat that it always gives me when I use it.
      It does have it's drawbacks though.
      It can hide?, remove?, blur?, your subtle high lights. (Not sure what the right word is, but your high lights can disappear. This has only happened to me once, when I was painting my Behir, and I was not a happy camper.
      Went back and did them again a little stronger, and didn't have the problem again...
      Spray sealers can 'Frost' if they are sprayed on in areas of high humidity. This will make you tear your hair out, as your wonderful paint job now looks like it has been out in the cold over night....
      I have fixed this at last once by re spraying in a non humid environment, but not something I want to experience again....
      When I need to put Decals, or water slide transfers as they are sometimes known, I will use Glosscote on the model before doing the decaling. The reason for this is that the Gloss finish is much smoother, making the decal fit to the model better. (there are other things that I do as well, but this isn't about decaling)
      I have read that some folks will Glosscote, then Dullcote their gaming pieces, as the Glosscote offers better protection, and the Dullcote takes the shine back off...
      The only difference in the cans is the cap of the Glosscote is clear, while the Dullcote looks frosted, so I have started writting on the cans with a sharpie so that I am sure which is which.
      I have some 30 year old Polly S Flat Finish brush on sealer, as well as Testors Aztek Clear Matte Airbrush sealer, but I have used neither as of now...
      I also have a pot of GW 'Ardcote, that I bought not knowing it is nothing more than a clear gloss sealer. I have used this on gems or critter tongues, things I want shiny, but as it gets applied to my minis after Dullcote, I don't know how it would react to paint.
      I know that our hosts Reaper make a brush on sealer, but I have no experience with it...
      So chime in folks with your experiences and brands of sealers that you use!
      George
    • By 72moonglum
      So all, I just finished something this morning, the combination of middle age and wanting to get things done before people start waking up and make me do other random fun things (like take down the Christmas decorations) and I want to seal it.  I normally wait for a day for whatever reason, but I'd like to get this figure finished and move on.  Is there a recommended minimum drying time for paint before you throw varnish on it?
  • Who's Online   6 Members, 0 Anonymous, 55 Guests (See full list)
