Small fire elemental
EvilJames
  • Replies 4
For anyone interested, the base was made by gluing gravel down on the base and then painting it after it dried with the same technique used for the elemental. plus I used a little bit of lefter over caulk from redoing our kitchen to add tiny flames in the coals. I stuck a tiny bit of the caulk down and the feathered it up a bit with a toothpick. when that dried I painted it using the same technique as everything else just smaller and less elaborate.
