Elven Papercraft tower and wall set - Lord Szesze Works [Merged]
SamuraiJack
  • Replies 48
It is a great looking set - and every time I see it I think that I want to run a Fantasy Craft game set in the Elder Scrolls setting.... :wub:
That texture just say Ayelid Ruins to me.
The Auld Grump
*EDIT* Less than three days left on this one!
Edited by ladystorm
removed animated gif
So this particular project is almost over, and I'm sort of conflicted as to whether I want to buy more paper craft terrain when I haven't actually assembled any.  :unsure:   Um, does anyone know how much time assembly would take?  Roughly??  It's a really pretty set and the bobby pin thing is neat, but I'm not sure how much I want to invest in something I haven't tried.
It's generally super easy and the small tips to improve the look are super easy also. Individual pieces don't take very long, about the time or less then it takes to clean, prep, and prime a mini. Doing a handful at a time in assembly line style saves time but can get tedious if doing a bunch at once, like minis. Handful and bunch being non-technical terms and only each person can determine what that quantity is.
And you already have all the tools you need. Razor knife, ruler, scissors, and glue. I like to use super glue mostly, it sets up super quick so no holding pieces waiting for wood or white glue to dry. And if you accidentally cut the wrong tab off, super glue will join to pieces of cardstock edge to edge. If it's a piece that needs to be slid or fit adjusted then I'll use the smallest amount of Elmers school glue.
Thanks!  I've been thinking I should start on assembling the few things I have in hand already, looks easy enough that I could do it in the evenings.  Plus I could let my kids use it with Bones and not worry about anything getting broken.  Now I'm just waffling about pledge levels.
