Another Cry for Help. Ocean Cliff Base
Again not sure the right thread for this, sorry if I'm putting them in the wrong section.
Baugi, you have created a monster, basing has now become a bit of an obsession.
So my idea is this dude on a high cliff overlooking the ocean. How high should I make the cliff? Right now he seems huge. Thanks!post-13108-0-78357000-1409173068_thumb.jpg
I was just fishing on the ocean in an area with a good number of cliff faces falling into the sea (great places to jig for cod, but that's a different matter) A lot of the cliffs rose between ten and twenty feet above the water. So if you want to get the feeling of a real 'cliff' you may want to go as much as twice the figure's height. Honestly though, I wouldn't. Maybe only a couple more layers of cork higher.  I would also think about doing a bit of an overhang over the water where you have it curving back around the cd's center to give the feeling of waves having worn at the rocks over the years.
What TGP said. You can give the impression of more height by having the top of the cliff jutting out, not the bottom. Basically flip what you've got there upside down. I've never tried it on that scale before though. Give it a shot!
Thanks all for your replies very helpful.
Dry fit it together with the lowest layer of cork undercut by the water. See what that looks like.
If you have already glued all that cork, never mind.
Nope not glued. I flipped and shifted some pieces around, created some jutting. It is looking a lot better now, as well as creating a neat little sea cave area.
 Ah yes, good points. Thanks
    • By Thrym
      Yeah, another base. Shocker, I know.  It's one I've been thinking about for years, basically, since I bought the beads that are in it.
      So, the premise:
      I use the air-dry clay hexes from the previous project as well as these beads I bought at Walmart so long ago. The Bugle Beads are hex-shaped and iridescent.  The color on the tube is labeled as "black iris."
      I build a flat of the hexes and use the beads upright on a portion of the base to represent an unusual terrain.  I use a pill bottle shell along one edge to build the terrain upward on that edge more easily.  I'll peel that off later.
      So here's the bottom layer of the piece.
      The front layer is as high as it will go.  The next layer will go to the top of the beads and also be flat.  The last layer will be more like a hill on the other side of the beads.
      Now if this was for a mech it would look like pilings holding back the earth.  I will use more of them here than just along the fronts.
      Stay tuned. Enjoy. Please, stay safe.
    • By Metalchaos
      Hello everyone, here are pictures of a 77341 Lioness. This Bones model was sculpted by Geoff Valley. I painted it as a Black (Blue) Panther.
      I kept the original base and sculpted additional high grass around to incorporate it to a larger 2 inches square base. The trees are dried roots.
    • By Glitterwolf
      I always wanted to paint a Cronosaurus so when Antimatter Games offered on through a Kickstarter I took it.
      In hindsight I regret getting the FDM printed version, I should have gone for the resin one since you can clearly see the printlines on this one.
      On the other hand it was a good deal and it helped me to choose what kind of printer I wanted.
      This came preprinted
      Part of my Lost World Project.
      WIP Here:
      https://forum.reapermini.com/index.php?/topic/69308-lost-world-project-glitterwolf-paints-coldblooded-creatures-and-conquistadores/page/164/#comments
      Hope you enjoy the beastie.
    • By Dae
      After several iterations of painting and base, I'm finally happy with my Griffon and I'm calling it finished!
      The mini ended up looking a bit cartoony
      I did go for something else initially, but it seemed too plain for a griffon, so I was happy to exchange realism for 'striking'. More on PSA.
      And I just finished redoing the base -- thanks for support on the WIP board.
    • By Dae
      I planned to go for the coloring suggestion on the box, except with brighter feathers. After base coat and a wash it seemed to turn rather plain. I keep the underside this way, while for the top side of the wings I started adding some variation to the feathers, gradually daring to add more detail and contrast. Took a while to get there, but in the end I was happy and called it finished. I even took a fun picture with it:
      But now that I'm a few minis wiser, I demoted him from finished to lacking base. And this is where I am stuck now.
      I had this plan of making a sandstone cliff looking base. I positioned him and started building up terrain, working carefully not to damage the finished mini. I colored some stones of various sizes in a few colors so I don't need to paint as much around the mini and I started to glue my rocks carefully around the base.
      I kept working on it for hours thinking I am getting somewhere, but once I took a break and looked at it again from all sides... I stand by my rocks, I think in a few steps they'll look great, but the scene makes no sense. These are not cliffs, more like a stone quarry, what would a griffon be doing there? - that's too specific and unlikely.
      Time to "delete" this somehow and start over... Wish me luck!
      https://pocketsizedadventurers.wordpress.com/2019/12/18/griffon-wings/
  • Who's Online   22 Members, 2 Anonymous, 42 Guests (See full list)
