Considering N scale / 10 mm terrain and buildings for CAV
Has anyone got recommendations for terrain of a suitable scale for CAV robots, with a particular focus on buildings?
I am told the scale is 10mm, which I am told is about 1/180, or model railroad N scale.
There are a lot of readymade and kit model railroad buildings out there, although most of them seem to be smaller and more rural or historical. Are they worth the price?
Hydrocal is like plaster, isn't it? So a hydrocal building would be pretty heavy. Styrene, however, sounds a bit fragile. But I don't know; it's not my area of expertise.
I have some vision of playing the game among futuristic, relatively tall skyscrapers. While I'm pretty sure I can make some out of half-gallon milk cartons, I am wondering what other possibilities are out there and if anyone can recommend -- or warn against -- products or processes.
  • Replies 25
Hydrocal is indeed like plaster.  Styrene is just plastic and is used in lots of model kits, definitely no more fragile than any other plastic model.  You can get all kinds of building kits and pre-assembled buildings for N scale train layouts but they aren't usually cheap.  Plastruct and Evergreen make lots of useful plastic sheets (plain and patterened), pipes, ibeams, etc. for making your own stuff or modifying kits.  I find lots of interesting shapes for use in building terrain while wandering around hardware stores.
Styrene is just a type of plastic. In foam form is referred to as styrofoam but it can be a hard plastic as well.
I've actually had some luck with 28mm terrain. These are some gothic snap together kits I got off Amazon.
8754215727_b0185b570c.jpgIMG_1800 by LittleRukh, on Flickr
I also go for the scrap terrain. A lot of my stuff is packing inserts or bits of industrial machinery.
A note on scale, CAVs are only about 30' tall so equivalent to a three story building so if you're going for Pacific Rim style games you'll need smaller scale buildings.
A CAV would only be slightly taller than Gypsy Danger's foot
Hydrocal is a mix of plaster of paris and portland cement. Significantly stronger than the former, so you can make what's called "hard-shell" terrain from paper and hydrocal.
For city terrain inspiration, you might take a look at this Flickr photo stream:
https://www.flickr.com/photos/[email protected]/sets/72157603736133777/
Bachmann is probably your best bet for plastic model kits in N-scale (which is technically 1:160 scale). Modern buildings are possibly easier to find in N than in HO.
An N scale skyscraper is still going to be very tall.  The Empire State would be 8 feet.
Well... in all candor... most buildings aren't the Empire State building. Or even the Sears Tower.
Be interesting to see a CAV game set in Manhattan, though...
Most buildings are not skyscrapers.
