Need help finding biggish hands holding weapons for conversion
So I have this brilliant set: http://www.reapermini.com/OnlineStore/female%20orc/sku-up/02553
The evil sorceress is fun, but I'll be honest, I got it for the skeletal ogre, or orc, or whatever he is. He's awesome!
Unfortunately, he's holding a towel. Or a cerement, or a ritual cloth or whatever. Like a butler.
Fortunately, the hands-and-towel unit is a separate bit.
I'd like to convert him to a skeletal ogre holding weapons. But it turns out the Boneyard is not so simply searched.
Can anyone recommend Reaper Boneyard bits which are essentially hands, roughly human sized (but a tad larger is okay), holding weapons?
I'd prefer one-handed weapons so I don't have to worry about fitting so much. Any kind is acceptable. Thanks.
The first thing that springs to mind is Reven. Type in "reven," and you'll get probably half a dozen to a dozen figs with separate weapon-hands.
Unfortunately, many are double handed weapons. I know you said you don't want to do much fiddling, but it's a start.
Mash, Half-Ogre also comes to mind, but again... Fiddling.
 It may look a bit odd for a skeleton to have hands with flesh on them, you'd probably want a set of gauntlets or gloves instead of actual hands...
Although I'm pretty sure there's going to be "fiddling" involved any way you look at it. (It wouldn't be terribly hard to simply clip the hands off of the cloak and open them up...)
 There are these claws from the creature components if you don't mind non-human-looking...
Hey, I picked up that same mini in the boneyard at ReaperCon last year with the same intention. I'm sorry to report that I haven't put new hands on mine yet.
Skeletal Giant (http://www.reapermini.com/OnlineStore/giant%20undead/sku-up/02742) has a left arm that is separate from the main body that would probably work. I'll double check sizing once I get home.
I echo gloves/gauntlets idea.
Possiblly, it is much easier to pick up an appropriate mini and chop their hands off.
Aside from reaper minis, GW's plastic Chaos Warriors have relatively larger armored hands. As they are made of plastic, much easier than metals to chop off. You may buy some as bits somewhere (eBay, neaby shop and such).
 Nope, too big - the ogre/orc skeleton has hands about 1.5 times the size of an average human, and the skeleton giant's hands are about twice as large as his...
If you're going to go GW, might as well just get some of their skeletons. The $10 booster box has five cheap skellies with big, bulbous skeleton hands, spears and shields, just waiting to be clipped at the wrist and glued on.
If you choose to go the GW route, give me  a shout.
03220C. Barrow Warden Hands (choice of two RH weaps)
14029B. Pirate sword RH
14354. Sword in a skeletal left hand
____
Edit:
06115D. Choice of 3 hand weapons; looks like all RH
Try searching for "Arachno"; it should bring up several skeletons with six arms. You could order one; deprive it of two arms at the wrists; it would still have 2-4 weapons remaining.
Edited by TGP
Why not use the existing hands and treat it as a traditional weapon swap?
This would be the only extra step.  And most of that is just material removal.
Use a jeweler's saw to cut away the bulk of the cloak, and then a file to clean it up until you have solid fists.
With a pin vice or Dremel, drill a hole through the fist.
Make a small cut along the thumb to open it up.
Insert replacement weapon.  Add drop of superglue.  Close hand around new hilt.
Done.
No need to find new hands.  You can put into the hand(s) whatever weapon you want.
Because once the cloak is chopped away all that is left would be a pair of tiny pewter nuggets less than 5mm in diameter. Impossibly small to drill, file, carve, and fit for a weapon.
And that is at least 5 steps.
Perhaps they are too small of you to work with…
But they are far from impossible to modify.  And other than removing the cloak, it is no different than any other weapon swap.
If you were really worried, you could pin and attach the hands to the wrists before you removed the cloak, and then remove the cloak and perform the weapon insertion.
I don't have a picture of it, but I modified this skeleton already as follows: 1. sawed the hands off of the cloak. 2. Drilled holes into the hands. 3. Pinned the hands to the arms in a way to coincide with holding a big 2-H weapon. 4. Put a paper clip through those holes. 5. Found an old oversized axe head and drilled it to fit the paper clip. 6. Green stuff a wood grain handle and better finger bones.
I wish I had a pic of it. It turned out great like Gnoll Skeleton holding a Halberd. The person I painted and converted it for was jazzed.
    • By Metalchaos
      Good day everyone, I will share here my progression on a project I wish to do for a long time. I already know all the parts I'll be using for this diorama. Starting with the carefree 03082 Ingrid sculpted by Derek Schubert (I'm converting her as a svirfneblin prospector), accompanied by her faithful familiar the 14453 hunting cat sculpted by Sandra Garrity. They are taken as prey by a 03602 stone lurker sculpted by Kevin Williams. I will also add a 02018 bat from the familiar pack 1 hanging somewhere on the rock wall. I already worked on Ingrid. I removed the base and give her a pickaxe. I made her tool with a paperclip and a piece of scrap metal. This all-project idea started with the gemstone she’s holding in her left hand.
    • By dks
      Nearly two years after I started a thread for showing off the figures of my Pathfinder Society characters, I present the second figure.
      (For that thread about the first character, click here: link.)
      This is Sister Ayano, a kitsune archer (level 8 now: paladin 5 of Shelyn / zen-archer monk 3).
      I did some extensive conversion to the elf archer Caerwynn, from the Warlord line.
      Here is the finished Ayano:
      You can see the Work-in-Progress thread for her here: link.
      You may have noticed the concept art for two kitsune figures in the "Eastern Legends" stretch-goal from the recent Bones III Kickstarter.  I'll be sculpting those two.  So if you like the way Ayano the kitsune looks and you wish Reaper made others figures like her ... well, you're in luck (sort of).
      Enjoy,
      Derek
    • By Metalchaos
      Here's another one!
      The Chimeric Aberration is something I was inspired to build after reading about Chimeric Creature in D&D Monster Manual 2. In the book, they give the example of a Chimeric ankheg which has the head and front legs of and ankheg with a goat and a white dragon head.
      I'm calling my monster a Chimeric Aberration, because it doesn't have the traits of a goat and a chromatic dragon which are normally present on a Chimeric Creature. Instead, my chaotic hybrid will be the result of a mad wizard experiment that went terribly wrong. It will have the main features of a Giant Hound, a Deadborn Vulture head will stretch out from the right side of the monster and an Hulking Insect head will sit on the left side.
      My plan is to use a 02817 Moor Hound for the main body. Then, I will use both heads from 03069, Hooked Hulk witch are included in 03440 Creature Components pack 2 along with 14456 Mastema’s tail included in 03334 Creature Components. I will also use 03641 Gunslinger’s wings to add another characteristic of the Vulture. I’ve considered larger wings like those of 02065 Greycloud the Pegasus and maybe 02729 Mephisto’s wings would have been even more appropriate but I don‘t have them at hand. I may swap some of its paw for claw and/or palmed foot as well.
      For the colors, I thought of painting the main body green like a Cù-Sìth from the Scottish folklore. The additional head will have traditional vulture and insect colors. Voilà, It should be charming.
    • By Metalchaos
      Hello everyone, here are some pictures of a 02126, Arachno-Assassin sculpted by Bob Ridolfi. I had this damaged mini for a long time and I decided to replace its upper left hand falchion for a sword from the 02455, Weapons pack IV. It was a very fun and easy model to paint. I intend to use it as a "boss" in a major encounter, so I painted it in red to increase the focus on it and point out how dangerous it is. The bluish bladed sword will be magical, maybe even cursed.
    • By Metalchaos
      Hello everyone, here's what I painted last week, a Skeleton Horde by Games Workshop / Citadel Miniatures from 1986. I mounted them on 25mm base and converted a few of them. I used remaining parts from other minis and changed some shields, skulls and weapons. I also printed two army trays to be able to move them more easily and change their arrangement on the game table. There's 16 skeletons in total and I intend to use them during future D&D games.
      More pictures under the spoiler (64 pictures).
  • Who's Online   20 Members, 0 Anonymous, 42 Guests (See full list)
