Removing Oil Paints
Xymor
Hay All,
My friend just gave me an old Partha dragon that he never finished and it has oil baised paint on it and I was woundering how to take it off so I could paint it. Would it be the same as taking off acrilic paint or do I need to do some thing else to take it off.
  • Replies 7
The Dragon is pewter. Is acetone better, I can alwise go get some?
I just don't know if those chemicles are safe on pewter. i guess if they don't melt plastic containers they should be safe enough.
BTW pine sol is also used to strip metal minis. I just prefer acetone for speed and because it can strip a mage knight in 30 seconds.
  6. How do I strip paint?
      There are several substances which will work, outlined below.  Other
      than the top two (which are the author's personal default choices),
      they're in no particular order.
        a) Pine Sol for a 24-hour soak then brush off remaining paint with
    a soft toothbrush.  Works great on metal.  Brian Lojeck
            <[email protected]> ran extensive tests on Citadel plastic
    genestealers and Pine Sol for paint removal.  Here are his
    results:
            "I soaked the plastic genestealer in about 50-50 Pine Sol/water
    solution for 7-8 hours (a nights sleep).  The plastic didn't seem
    softer, the detail didn't seem any worse, and the paint came off
    pretty well (as it always does with Pine Sol. it was hard getting
    the paint out of the cracks (I soaked in acetone to do that)."
    Then he soaked some unpainted Citadel plastic figures in another
    50-50 Pine Sol/water solution:
            "The figure survived whole, without softening or loss of detail.
            The solution turned milky white about 30 minutes after the
    experiment started, but had cleared back to golden by morning."
    <Britt's note - that's the standard Pine Sol reaction in water,
    does same when I'm cleaning the toilet.>  Brian left the figures
    soaking another 48 hours and they didn't mar under the toothbrush
    bristles, but he was able to stick his fingernail into the plastic
    about 1/16".  It looks like the 50-50 mix is the key.  Certain
    other pine-oil cleaners of less strength than Pine Sol are on the
    market.  Anyone who tests these on plastic figures is encouraged
    to send the author your results for inclusion here.
        b) Chameleon model paint stipper from Custom Hobbyist, Inc. found in
    model railroad shops.  Sort of expensive, but _reusable_, water
    soluable, and really fast.
        c) Floquil/Polly S Dio-Sol.  Also purportedly dissolves glue.
    Won't harm your plastic as much as Pine Sol, but reportedly loses
    detail due to the amount of scrubbing necessary for the recesses.
        d) Brake fluid.  Won't melt your plastic, but might melt your hands...
    2-3 hour soak _maximum_, usually works faster.
        e) Dettol, the pharmaceutical cleaner.  Works much like Pine Sol, but
    I have no information on its potential to melt plastic.  Though it
    didn't melt the base on the test figure, bases probably aren't
    polystyrene.  It did remove glue, though.  (Thanks to Steve Gill
    for this bit.)
        f) "The Sainsbury's home brand pine disinfectant (UK).
    It actually gives pine oil as one of it's ingredients.  In testing
            it works very well and costs roughly 99p per 750ml bottle."  (More
            thanks to Steve Gill who found this product and tested it.)
        g) Acetone nail polish remover.  Smells, peels skin, melts plastic,
    takes paint off metal like a champ.
        h) Isopropyl alcohol, the stronger the better.  Lab grade, if you
    can get it.  This seems to be the safest product for use on plastic
    miniatures, and also the most universally available.  "It takes
    off acrylic paints in almost no time, but reportedly doesn't do as
    good a job in crevices as Pine Sol does.  As for oil-based
    paints...  "after several days of soaking, renewing renewing the
    solution, scrubbing... the figurine I tested has still a good
    portion of its paint on, mainly on the zones that I cannot access
    with a toothbrush." - Magali Mathieu
        i) Easy-Off oven cleaner.  And wear gloves.  It reportedly will not
    harm metal or plastic minis.  Remember to use GOOD ventilation.
    (Thanks to Richard Kurtin for this information.)
        j) "Bix Paint Stripper.  Buy the sprayable, rather than the jelly
    mix. It smells bad, is volatile, and will go after your skin if
    you forget your gloves.  It will remove enamel paint with minimal
    scrubbing, and does a pretty good job on acrylic. It _WILL_ eat
    plastic, so don't even think about putting your Genestealers
    in it. Also, you'll probably find yourself replacing your
    toothbrush more often." - Pete Siekierski
        k) "Methylene Chloride.  One of the components of Bix Paint Stripper,
    MC is rarely available in its purest form (I've no idea where my
    dad got his can, and neither does he!). It is extremely volatile.
    Do not light up near a can of methylene chloride! It will also do
    a number on your skin, making it wrinkled like you've been all day
    in the bath. Wear gloves! Also, be sure not to wear metal jewelry.
    Because of its high rate of evaporation, MC "chills" metal, and
    this can be very uncomfortable if you immerse a ring in it...
            On the plus side, pure methylene chloride is even more effective
            than Bix, which contains only a small amount. It burns right
    through any kind of paint that you'd care to put on a miniature,
    and will reduce plastic Genestealers to shapeless lumps (big
    deal, heavy flamers do that too!). It will "chill" lead or pewter
    miniatures, so they will feel cold to the touch, but in a room-
    temperature environment, this will wear off quickly. Like the Bix
    stripper, you'll find yourself replacing your toothbrushes more
    often." -  Pete Siekierski <[email protected]>
    (Archiver's note: Proper dental hygene suggest that you replace
    your toothbrushes every other month anyway...)
        l) Poxy Scum <[email protected]> in Australia also offers this
    info:  "I found that Rexona Sport pump spray, not the aerosole
    works quite well, almost immediately on acrylic Citadel paints.
    It is best used for spot cleaning as it works almost instantly to
    soften paint and is quite safe on plastic and metal.
      As you can see, there are a lot of products that will remove paint.  Most
      are caustic.  The author recommends a non-caustic product.  Pine oil
      cleaner will remove any type of paint (acrylic, oil-based, Rust-O-Leum,
      fingernail polish, etc.) from miniatures with no loss of detail, no
      caustic residue, and no hazardous fumes.  It's safe for metal miniatures
      and will not dissolve the glue holding parts together.  Pine-Sol is the
      best brand, as it's 19.9% pine oil, but any percentage over 5% pine oil
      will strip paint (it just requires a longer soak in the less-powerful
      cleaners).  It also works on paint that's been on for several years (the
      author successfully removed 10-year old Testors from a metal miniature
      with a 2-day Pine-Sol soak).
      For plastic miniatures, Pine Sol in a 50-50 solution with water, else
      isopropyl alcohol is your best bet.
      Dettol, a product from the UK, seems to work as the US Pine-Sol does
      in preliminary testing.  More information will be made available as
      testing continues.
      Simply place the miniature in a container which will allow full
      coverage, pour in enough pine oil cleaner to cover, and let it soak
      for 24 hours or more.  The longer the soak, the better the stripping
      (the author has soaked metal miniatures for over a week with no damage
      resulting).  If you're doing multiple miniatures, it's best to soak
      them seperately, if possible.  Once the paint starts to dissolve, it
      causes a sliminess that can get on the others.
      After the soaking, take an old toothbrush (dry) and scrub.  A soft
      bristled toothbrush is best, however using soft then stiff will get
      most everything without special work.  The finest details are kept,
      the paint comes off easily, and the smell doesn't try to knock you
      out.  If some paint remains stubborn, another soak will do the trick.
      (The tip of a toothpick is also good for crevasse-cleaning as are
      standard pipecleaners.)  Do wear gloves if you're skin-conscious.  The
      author doesn't and has never suffered for it, but others report peeling
      and irritated skin.
      NOTE:  Many people have complained about the pine-cleaner soak
      darkening the metal of the miniature.  The author just finished
      cleaning a lead miniature on which the acrylic paint had been for
      two years.  It soaked for 24 hours and was first scrubbed with a
      soft toothbrush then a stiff one until all the paint was removed.
      Then the soft brush was washed clean and hand soap (the bar of
      Ivory by the sink) was applied to the brush and the miniature was
      brushed down vigorously, as one would do teeth.  It took about 5
      minutes, but the lead shined up as good as the fresh-from-the-package
      figures it ended up beside on the shelf.  So the `dark metal'
      syndrome can be taken care of, if it's important to you and you
      care to spend the time.
