MSP: Deep Amethyst
  • Replies 2
I poked through and couldn't find a near-exact match, but I found some potential contenders that might be reasonably close.  This, of course, may vary because I have to try and match using monitor settings.  But if I was looking for a substitute, they're the ones I'd try out:
Violet Light:
http://www.reapermini.com/OnlineStore/Master%20Series%20Paints/sku-down/09266
And Twilight Purple and Gem Purple:
http://www.reapermini.com/OnlineStore/Master%20Series%20Paint%20High%20Density/sku-down/29819
http://www.reapermini.com/OnlineStore/Master%20Series%20Paint%20High%20Density/sku-down/29820
Combining those latter two might actually produce the closest result, if I had to guess.  But I don't know for sure, I don't have the colours to test.
  • Artists
Violet Light is a similar value, and is a blued purple. It has less blue in it than Deep Amethyst. None of the 'in print' purples are as blued as Deep Amethyst. I think your best bet would be to try adding a little blue in to Violet Light or Imperial Purple and seeing if you can mix something that's a little closer. (I did test swatches with a few paints to come to this conclusion, but don't have time right now to do mix tests, sorry.)
I loved that triad, too, I feel your pain!
