WIP: First try at a sculpting project
Recently Browsing 0 members
Similar Content
By MoonglowMinis
So i've got that trio of spiders from nolzur's.
They do not come with sculpted bases - unlike most of the nolzur's line. This isn't a huge issue, except that these suckers have a bunch of tiny spindly legs. I am worried about getting a good hold.
So I have a few questions:
1: how to fasten these guys to a base? Just glue the legs and hope, or pin them through the body like a flightstand?
2: how to sculpt/or assemble, suitable bases to compliment their spindly nature and ensure a better hold.
3: how to attach the spider in a way that I can paint underneath it OR should I find a way to glue it down after both parts are painted?
So the webbed victim shown in the photo above I have decided to leave out as a piece of scatter. There is a stone base (not pictured) that I have already glued to a reaper base for one of the spiders. Each of the spiders has a slightly different pose with their legs - which is made worse by them being bent out of shape. I'm hoping to use this as an advantage though, and pose each spider differently. One is rearing back with front legs up (this one I plan to glue to the supplied rocky base with the abdomen glued to the ground for extra support.
Another spider has one side of legs kind of bent under a bit. I'm thinking this would look good mounted sideways, crawling up the side of a fallen log (not sure if I should try to sculpt this, or find a twig to glue to the base).
The last spider is pretty neutral, but I was thinking of posing it climbing down something just for variety.
Any advice about sculpting the bases vs gluing organic material or mounting something with narrow points of contact would be tremendously helpful. My indecision has lead to two weeks of no painting.
By Downfall
I recently finished a group of Reaper Bones miniatures. As they are so small they were a little hard to paint at some points. I'm fairly new painting miniatures so I was looking for some feedback and potentially some tips on how to improve in the future. All comments, advice, and constructive criticism is welcome.
My own main criticism with them is the highlights as I'm not 100% where/how to paint proper highlights to make a natural look without a ton of brush strokes.
By knarthex
So at Reapercon 2018, I scored the Duskwarden poster of Thregan Helmsplitter for my work at the auction, and of course, being the Duskwarden*, I have a couple of the minis as well.
So I was thinking of using him as my next PC, but as I have hair, I wanted my mini to also...
While working on another project with GS, as usual, I made to much, and decided to bite the bullet and do his hair...
What do you think?
Comments appreciated!
George
Doesn't Jacob Knochengard look like me???
By Rat13
Having just started a 45 figure batch paint of guardsmen, I decided a side project may be in order. Just a little something I could fiddle with off and on to disrupt the monotony and I knew just the project.
About a year ago, after I finished my first commissar, I thought it would be a good idea to paint all my commissars differently. That way I could tell all of my HQs or elites apart, but wouldn't you know it after a couple games I realized it was completely unnecessary. Having already started down that path however I decided to press on.
Within about the first week of pondering different color schemes I had a great idea. Unfortunately I lacked the skills and hobby confidence to attempt it. This past year I've managed to learn quite a bit though, especially about sculpting/working with greenstuff. So I think it's time to attempt a Hulk Hogan commissar.
First up was locating a good reference photo for both his moustache and boa (see above).
As the moustache was the trickier of the two I decided to start there. In a twist of fate getting a good texture was the easy part, but getting the proper size wasn't. After some back and forth I finally got the size correct. Then it was just a simple matter of using a pin and a toothpick to achieve a hair like texture.
This is what you get zooming in, but at a regular viewing distance I think it looks good.
Next came the boa. Try as I might I couldn't get a good feathery texture going. I could get a good amorphous blob/coral like texture though. Much like the moustache it'll fail upon close inspection but I think with a good paintjob it'll hold up just fine.
See I told you that moustache is passable with some distance.
Now it's just a matter of letting everything dry before priming. I guess it's a good thing we have holiday commitments for the next couple days.
As with any greenstuff project you always end up with some leftovers. After adding a skull to the Hulkster's base I thought I'd share the wealth with a few random models from my desk.
Who's Online 8 Members, 0 Anonymous, 37 Guests (See full list)
