Modular Magnetic Wargaming Tabletop Building Terrain
SamuraiJack
About
67c7dc5f53e65e4b76158897a740698a_origina
A ground-breaking tabletop building system, made of durable, highly detailed, precise laser cut MDF and grey board. All buildings come ready to use, no glue required. THIS IS NOT A KIT!
6390d3ecf412194cc7b608848f2c5e98_origina
ce66cff47e926783cc6c9ac23ad243d1_origina
05c729a05ce64b7336617ea11f690c44_origina
938f00725fbceecd11fb6dc71bdf2679_origina
77efae6356b93105828663bfc1e588fc_origina
This unique system for 28mm tabletop games and RPG's uses strong earth magnets to attach the building exteriors (skins) to a base box.
eb99ea10052ab86fc7a4a9113459de73_origina
Construction couldn't be simpler! The magnetic system means the buildings can be easily and quickly assembled, disassembled and reassembled over and over in various combinations.
project video thumbnail
 PLAY
Not only can you change skins to create different building combinations from within a range, you can also select skins from other ranges depending on the game or period you wish to play. This cross-game terrain system means you can build a Wild West town one evening, then just by changing the skins on the base box, a fantasy village for a wargame the next.
 PLAY
All skins are pre-assembled and designed to flat-pack away. This  makes transportation much easier and considerably cuts down storage needed, keeping everyone happy.
What's more, your base box can be used as storage for your figures and other gaming elements, such as dice and tokens.
  • Replies 2
