Hey guys. I'm back after having my wisdom teeth removed :/ nasty surgery had to have some recovery. But I started painting again and I was wondering; am I getting speckling here? It used to be really bad but I diluted down a touch and I think it's better. Could use some help.
2 hours ago, Ratmaster2000 said:
Does look a little speckled, how far away was the airbrush? may need to get closer?
I was pretty close and I didn't want it too focused, like when you're super close. Would turning up the pressure help?
Things to try would be turning the pressure up, turning it down, thinning the paint more, thinning the paint with something different.
what type of brush are you using?
With my Grex and Iwata, I try to spray at around 5psi....
also what is your air source?
Do you have a moisture trap?
My brush is a Paasche TG-3F Double action, wow I've never tried that low. Lowest I've gone is like 10-12. Air source is the compressor that came with it. I don't have a moisture trap, is it necessary? It's not very humid where I live. EDIT: Just realized you meant on the compressor. Yes, it came with it. It was a package deal designed for airbrushes.
Edited by ThirstyBob
    • By lexomatic
      I do not understand how this mini is supposed to go together. There is a large hair bulge that is supposed to fit in the hollow of the back. I tried sliding and twisting and cannot get the head to fit on in a dry fit. I cant imagine doing this after painting.  I don't really want to try and paint  and be unable to get into corners. Has anyone posted this anywhere? Things got caught and I see white stress marks on the mini where I had to try and force it off and it makes me super nervous to try anything again.
      This is exactly why I would 100 times out of 100 take a poorly glued at the factory mini. It's effectively wasted money for me, because I can't do anything with it.
    • By Tigermanic
      I recently bought the 2 headed Troll "Lardgulp" to use as a boss in an upcoming battle for my play group. The problem is that compared to the reaper black Rock Troll I received he is not so intimidating...
      However, I've seen on other sites a new reaper black or bones 2 headed Troll for pre order. I was wondering if there were any pictures of it compared to the Rock troll, and when will it be available on the site properly?
    • By Kangaroorex
      This is the second of my dropfleet starter sets.  The fleet represents the United Colonies of Man (UCM).  After humanity was chased off the planet earth and forced to scatter to its colonies to lick their wounds, the colonies united and formed an armada to take back the home planet.  These ships are the final gasp of mankind to keep from becoming nests for a truly invasive species.  the game itself is a little different from Most because battles are fought in nearspace around planets.  The map is a planet viewed from low earth orbit  and the ships can move from high to middle and low orbits, each having an effect on the ship speed and who can attack what.  The game itself is pretty fast, a starter fleet battle will resolve in about an hour for us on the rare occasions when i get to play and the sides are pretty evenly matched although they have very different play styles.  TTcombat took over the license this year and saved the game from fading away and have put quite a bit of effort into new miniatures and rewriting the rules to fix problems and make the dropfleet game compatible with its companion game Dropzone.  now you can run a companion game allowing the two games to interact on a limited basis which, i think adds a lot to both sides, if you can find that many players...
      I decided to takes some liberties with these vessels.  i wanted each ship to be distinctive and easy to spot on the game board so the grid pattern built into the armor of the ship, which is usually blacked out, i lined in white and then traced over with various florescent colors from Scale 75.  The effect was not quite what I was after but it's still pretty good and certainly usable on the field of battle.  The ships are a starter set of 3 crusiers (2 heavy 1 light) and 4 frigates.  The base color is black with a midnight blue ghost tint and then highlighted with white and flouresents
      Hope you enjoy them!  I certainly enjoyed painting them!
    • By Kangaroorex
      Time to get the year started with a little space adventure!  It took me about a week of spare time to get this fleet assembled and painted.  Space ships are one of the few miniatures i find where less is more and although they look intensely detailed, there really isnt that much to work with.
      This is an enjoyable game that I wish i had the opportunity to play more often but, time being what it is, i am limited in what i am willing to teach people to do and I get tired of always having to explain the rules.  Anyway, the Scourge are a bunch of nasty alien body snatchers who have invaded earth, forcing the remanents of humanity to go hide in the colony worlds to rebuild for the re-invasion of earth.  They also have some of the coolest ships!  These were done mainly with airbrush work except for some of the lights and engine fire.  I started with the badger metal colored primer and then sprayed the front with plasma fluid ghost tint and the back with blue ghost tint winding up with a really wonderful color shift across the minis.  The last piece is a leftover Aquan dreadnought from a game called Firestorm Armada I used a slightly different color profile so it would blend with both this game and the original firestorm fleet (okay i have a soft spot for spaceships.  I just wish the games would play half as cool as they look!)  This is basically a starter fleet consisting of three versions of the Cruiser class and 4 Frigates.  That and as I said, the dreadnought for good measure!
      Thanks for looking!
    • By lexomatic
      So I've painted up a couple of sample pieces of my 4bot tiles and to try out an ice recipe. I thought I'd get some feedback. It seems a bit too sea glass for me.
      Phtalo green (yellow ink) +medium, then drybrush of teal, turquoise, pale blue, and adding white.
      Also included a pic of previous recipe using turquoise ink and pale blue, then white drybrush.
      And materials Thoughts?
  • Who's Online   10 Members, 1 Anonymous, 56 Guests (See full list)
