ThirstyBob
Airbrush losing pressure - Help!
So today when I started airbrushing, I noticed that after I sprayed a bit the pressure on the tank was dropping, which made it difficult to get an even coverage. I'd start at around 15psi, and it would hold for a couple seconds, then drop steadily until it was down at 5psi. Turning up the pressure did not help, it still dropped psi. I took out the needle and checked and cleaned it and the rest of the ab, then tried just shooting air through, without needle or anything but the nozzle lever. Same result. Seals are airtight at least until I start shooting air through. I have a Paasche TG-3F, bought it with the compressor in a package deal, compressor has a humidity filter on it.
EDIT: Just noticed that while air is going through the airbrush, adjusting the pressure does nothing at all. I can turn it up or down and it stays at 5psi. Unless I reduce the pressure below 5psi, then it goes down. Adjusting the pressure when I release the airbrush changes psi normally.
Edited by ThirstyBob
I know this may be a dumb question, but you mentioned a tank and humidity filter, did you make sure the tank and filter's valve releases are tight? I know I have drained my tank and filter, then next go around I get air leaking because I forgot to tighten the valves closed:(
What kind of compressor are you using and does it have an air storage tank?  Does it normally work and level out at a higher pressure with that brush?  It may be that the motor is wearing out and is having a hard time supplying the pressure to the brush.  Or as Ratmaster2000 said there could be an air leak in the system.  When not engaging the trigger of the brush can you hear air escaping anywhere?
For clarity, can you hear the piston running while the pressure is dropping?
I'm wondering if the regulator is not functional and not detecting the pressure drop correctly to turn the compressor back on to replenish pressure.
It's an auto shut off tank, it turns on for a few seconds when you power it on, and then turns off until air is released. So if the filters weren't tight, I believe it would turn on every few seconds? There is no sound of leaking either. The Airbrush works fine at first it's just problematic for getting even coats if the pressure drops down to 5psi. Would it be the motor if the compressor has no trouble running without the brush connected?
If you switch it on, wait for it to reach pressure, then leave it sitting there, without using the airbrush at all, how long until the compressor starts up again?
It doesn't ever, I usually leave the compressor on with a quick release valve on it that I just slot the airbrush into. Maybe I shouldn't be doing that?
Also the compressor is also a paasche brand compressor, came with the brush. I'll check the model number later.
You mean you always leave it on or just leave it on when you're using it? If you are always leaving it on and never draining the tank it's going to eventually rust out inside.
Your current problem sounds like the compressor isn't keeping up with the pressure demand. Does it take longer to build up to full pressure from empty than it used to? My guess would be a gasket in the compressor or the motor itself is wearing out.
It doesn't seem to , same speed to get up to full pressure, just drops after I start painting. I haven't had it for very long, under a year. I also don't use it very frequently. I may have put some extra strain on it by leaving it pressured up all the time though.
I'd probably start by using soapy water on all the connection point to verify there isn't a leak somewhere. A third possibility if it isn't a leak would be the regulator controlling the on and off. If it's a Paasche though, and you've had it for less than a year, you should just call them and ask. It should still be under warranty.
    • By Pineapple
      These are from the Ghosts of Midlam Manor Kickstarter.  I love these sculpts and I just got an airbrush, so I wanted to try sort of a blue zenithal ghost effect.  They are more blue than the camera shows, I'm still getting used to the photo booth and lighting.  (Plus I should probably use the real camera instead of my phone.)
      Overall I'm happy!
    • By Pineapple
      As with the other ghosts, I was playing around with quickly airbrushing a ghost effect.  I liked the green tone of these Bones 4 minis, but I'm not a big fan of translucent figures.  I wanted to paint over them, but keep the ghost vibe.  These are much greener in person.  I like them, but I think the blue ghosts in the other thread turned out a tad better.  These ended up a hair too bright for what I was going for, but it's all in the name of science! I might glaze them down a bit later.
    • By Mckenna35
      I've had this kit for quite a while now, to build for a friend who's a big Judge Dredd fan.  Due to circumstances I can't go into, he asked me if I could this one, along with Judge Anderson and possibly Judge Death put together and painted for him.  Second vinyl figure I've worked on, and I thought some of you might find it interesting.  First picture shows the components cut out and cleaned up.  The second is the major subassemblies.
      One of the tricks with this kind of kit is to fill the lower portions with plaster to add rigidity, weight and strength to the piece.  Without it, you run the risk of the vinyl buckling if it gets too hot after you've got the figure assembled.  Yeah, DON'T leave these kits out in direct sunlight!
      and here he is with all the primary assembly complete and ready for paint:
    • By paedia
      [Warning: lots of images incoming]
      Next up on my table are the miniatures from Cerebria: The Inside World, a boardgame from Mindclash Games in which the forces of Bliss and Gloom vie for control of an evolving personality.
      I'm going to try to do these two at a time (one from each team); the first two will be Harmony and Malice.
      Session 1 - prime + zenithal highlight
      Harmony
      Malice
      Session 2
      Harmony
      With the airbrush, I did base+shading of the wings and base of the body. Colors used:
      - Twilight Blue
      - Snow Shadow
      - Surf Aqua
      - Violet Light
      - Sunset Purple
      - Maggot White
      Malice
      For malice, I'm starting with the NMM-bronze-ish body. I base coated with Khaki Shadow, then used Ghoul Skin and Moldy Skin for initial highlighting. Shadows are Woodstain Brown and NMM Gold Shadow (which I am not that fond of for Gold, but seems to work well here). Any other color recommendations? I finished up the session with basing the skirt in Redstone.
    • By kristof65
      So my lovely bride got me an airbrush setup for Christmas, and I played with it for the first time last night. Over all, it worked out ok, but left me with some questions that the Airbrushing: The Compendium thread didn't answer:
      1. I "prime" my Bones with Brown Liner.   When I tested on some Orcs last night, this seemed to work pretty decently.  But given the hydrophobic nature of Bones, I didn't thin the Brown liner at all at first, then started adding a bit of water. It definitely seemed to help with the spraying as I thinned it, but I was worried about it beading up. So how do you deal with that on the first layer on Bones minis?
      2. how do you guys tack down your smaller Bones minis to prime with an airbrush? I found that that the pressure (around 18-20psi) was blowing the orcs all over the place, which led me to having to prime them individually, which defeated the purpose of being able to do a bunch at once.
      3. I got a sample bottle of the Stylenz primer at ReaperCon - I tried it on some CAVs, but it just beaded up.  Was that an issue with me and the airbrush, or just an issue with Stylenz and Bones?
  • Who's Online   35 Members, 1 Anonymous, 185 Guests (See full list)
