Light Striker Company
KAMUT
looking at the numbers perhaps its worth a try. Our light Striker sections work pretty good what if 3 sections were assembled with a 4th section as a light fire support section. to round them off abit, we threw in 4 tsuisekis and 2 OBCS. So here it is, a Light Striker Company
7500 points
2 OBCS
Command troop (1598 points)
Talon (446)
-Ace Pilot
-Elite WSO
-armor upgraded
-strip the ECCM
-+2mm upgrade
Strike Puma (399)
-Elite Pilot
-Veteran WSO
-Armor upgraded
-TL system modified
-ECM system modified
-Breeder upgrade
-ECCM system added
Strike Puma (399)
-Elite Pilot
-Veteran WSO
-Armor upgraded
-TL system modified
-Breeder upgrade
-ECCM system added
Strike Raptor (354)
-Veteran pilot
-Veteran WSO
-Armor upgraded
-Breeder upgrade
-TL upgrade
-ECM upgrade
-Breeder upgrade
-ECCM stripped, CLP added
Light Striker 1 (1518 points)
Talon (366)
-Elite Pilot
-Veteran WSO
-armor upgraded
-strip the ECCM
-+2mm upgrade
Strike Puma (399)
-Elite Pilot
-Veteran WSO
-Armor upgraded
-TL system modified
-Breeder upgrade
-ECCM system added
Strike Puma (399)
-Elite Pilot
-Veteran WSO
-Armor upgraded
-TL system modified
-Breeder upgrade
-ECCM system added
Strike Raptor (354)
-Veteran pilot
-Veteran WSO
-Armor upgraded
-Breeder upgrade
-TL upgrade
-ECM upgrade
-Breeder upgrade
Light Striker 2 (1518 points)
Talon (366)
-Elite Pilot
-Veteran WSO
-armor upgraded
-strip the ECCM
-+2mm upgrade
Strike Puma (399)
-Elite Pilot
-Veteran WSO
-Armor upgraded
-TL system modified
-Breeder upgrade
-ECCM system added
Strike Puma (399)
-Elite Pilot
-Veteran WSO
-Armor upgraded
-TL system modified
-Breeder upgrade
-ECCM system added
Strike Raptor (354)
-Veteran pilot
-Veteran WSO
-Armor upgraded
-Breeder upgrade
-TL upgrade
-ECM upgrade
-Breeder upgrade
Light Fire Support (1378 points)
Talon (391)
-Veteran Pilot
-Elite WSO
-armor upgraded
-strip the ECCM, add CLP
-+2mm upgrade
Strike Raptor (329)
-Veteran pilot
-Veteran WSO
-Armor upgraded
-Breeder upgrade
-TL upgrade
-ECM upgrade
-Breeder upgrade
-ECCM stripped,
Strike Raptor (329)
-Veteran pilot
-Veteran WSO
-Armor upgraded
-Breeder upgrade
-TL upgrade
-ECM upgrade
-Breeder upgrade
-ECCM stripped,
Strike Raptor (329)
-Veteran pilot
-Veteran WSO
-Armor upgraded
-Breeder upgrade
-TL upgrade
-ECM upgrade
-Breeder upgrade
-ECCM stripped
Air Support (1272 points)
Tsuiseki (318 points)
-Veteran pilot
-Veteran WSO
-Armor upgraded
-Veteran pilot
-Veteran WSO
-Armor upgraded
-Veteran pilot
-Veteran WSO
-Armor upgraded
-Veteran pilot
-Veteran WSO
-Armor upgraded
Any suggestions and modifications are welcomed.
  • Replies 3
one of my favorite upgrades for the Tsuiseki is to swap its gun for the one off the Kikyu.
why you ask? better punch against Soft targets, and when power starts to become an issue, it drops off the chart anyways.
IRC it costs about +19 pts after all is said and done.
:upside: Can't recommend much for the Talons / Pumas / Raptors, I don't have any play time with them ::(:
Tim
hey I'm learning to enjoy the Vector primary guns on the Tsuiseki
+3/+6 at range 40 and you still get to keep the secondaries as is, I'm debating just making her my primary bird, and keeping kikyu around for clean up.
