I'm painting a mini with a light source, and decided to rebase the beastie with some water effects, probably epoxy resin.  I'll probably try to make the water at least slightly rough, creating interest for the eye.  I woke up in a cold sweat this morning realizing that the light source should be reflected (or possibly just highlighted) in/on the water.
My initial thought was to:
  1. lightly (heh) color the bottom of the pool as if it were dry and lit by the light source
  2. pour and texture the water
  3. highlight the water by drybrushing from the light source out.
My concern about this is that if the viewer looks toward the light, the surfaces of any wavelets will be highlighted on the opposite side from the POV.  In other words, the viewer will see the undersides or backsides of any highlights through the translucent wavelets, and this might not look the way the viewer expects.
Has anyone done this?  I looked around for a few examples but although there are plenty of doing wave effects (froth and foam), I haven't found any yet that look like translucent glare.
Painted specular reflections (the core of what makes NMM) can really only look right from a single point of view. You can live with the single preferred point of view; it's not a terrible thing. You can even force a single PoV if you do something like a shadow box.
You can also get away with an assumed zenithal light source (presumably the sun), but if you want a light trail on water (for instance), that's going to be point-of-view limited.
As to drybrushing, be aware that the technique adds texture. If the water is rough enough, that's not necessarily a problem. And foam is opaque anyway, so opaque paint can work. If you're intending a rippled surface, dry-brushing with opaque paint is probably not going to do what you want.
My only comment: I've done a lot of bases with both 2 part epoxy resin and Woodland Scenics Water Effects. The epoxy is great for smooth surfaces; I'm not sure how one would make ripples that don't smooth themselves out. For that I'd use Water Effects.
6 minutes ago, GodOfCheese said:
I had planned to use epoxy resin and then add clear caulk to the top to create the ripples, but now I totally want to try the straw technique.  I don't need much rippling-- the figure's on top of rocks and I want to make it look like the rocks have vibrated the water.
Timing is important. If you do it too early, it has no effect. If you wait too long, you get no ripples.
Also, don't hyperventilate and face-plant into the epoxy. It's not a good look. :poke:
  • Haha 4
    • By Samedi
      Finally varnished and ready for the table: Sepp, Brunhilde and Urs.
      I painted them up to kick off my Rangers of Shadow Deep Project. More infos and a bit of backstory can be found in this WIP.
      Those three are my first attempt at OSL. Luckily, I did not have to make this journey alone: I'd like to thank @Geoff Davis for a great class at RVU and an even better private lesson via zoom.
      Enjoy, C&C very welcome!
    • By Geoff Davis
      A Hellcat Hacker for my Corregidor Nomads team for Infinity.
    • By Metalchaos
      Hello everyone, here are pictures of the last Dark Dwarf I painted for my Duergar squad. I converted a 44109, Enlarged Dark Dwarf Smiter sculpted by Bobby Jackson to make it look more like a Striker. I changed the original hammer head for a 3D printed two sided meat tenderizer and added the eye patch. Thanks to Derek feedback, I really pushed myself on this one. I think I spent something like 3 or 4 hours on the beard only. It is standing on a 2 inches square base. The ball and chain are made of Milliput and a 3mm hobby chain. Your comments are welcome. Group pictures coming soon.
    • By Metalchaos
      Enlarge! Hello everyone, here are pictures of the 44109, Enlarged Dark Dwarf Smiter I completed last night. The size of this model allowed me to add more texture on the leather. I also added light effect on the face and the shield rivets. For those of you who may wonder, Dark Dwarves (Duergar) can once a day use their spell-like ability to enlarge themselves. This Bones Black model was sculpted by Bobby Jackson.
    • By Darcstaar
      I’ve been going through BONES I mostly in order, doing several WIP.  This was the next.  I wanted to try to improve on my OSL so he got a green magic glowing gem.  Still not great, but the idea comes across.
      Link to WIP.
      https://forum.reapermini.com/index.php?/topic/92763-darcstaar-vs-bones-i-ep-10-satheras/&tab=comments#comment-1965284
      I didn’t bother trying to paint his eyes due to the extreme shadowing...
  • Who's Online   17 Members, 2 Anonymous, 40 Guests (See full list)
