Logging in Problems?
ttuckerman
Question,
When at work I log in without the "remember me" option.
This was never a problem.
Lately I get logged out within literally seconds.
Alsmost impossible to post anything or like anything because of that.
Is this another glitch from the updates?
Like the dissappearance of the option to follow threads? ( I mean it's there, but it keeps erasing the content).
@kit ???
The erasing of the following content seemes to be caused by the party that gives the updates.
But you're customers then, right?
It causes troubles for the forum users, they should fix this.
  • Replies 18
When asking someone to debug an issue, it helps to provide as much information as possible.  These are the first questions that I would ask were I in his shoes:
When did this behavior start?
Do you see this behavior at home as well?  If you have a smartphone or tablet, do you see this behavior on them?
At work, do you have a browser extension that deletes cookies?
If you only see this issue at work, were any changes announced around the time this behavior started?
This behaviour started a month maybe two months ago, but it gets worse every day.
Our Browser does not delete cookies unless I do that manually.
My work System has not changed and logging in like this has never posed a problem before that.
One thing though.
It is worse in the morning, maybe because I'm European?
I mean that's night for you, maybe the forum system is updating then?
The later it gets the longer I stay logged in.
Edited by Glitterwolf
  • Confused 2
I've had a similar problem with the store, but not the forum.  Since I think they're on different servers they shouldn't be related issues, but I've never been logged out within seconds anywhere else.  I agree it's frustrating, especially since you probably spend more time reading the forums than shopping.
You might want to make sure your computer is updated just in case, if you can.
