Ordnance 8 - M10 Tank Destroyer
GlenP
  • Replies 12
Thanks H/K/G! I think weathering is a key element in tank models. I think it was Shep Paine who said tanks don't move on the land; they move through it. So, I add a degree of scrapes, scratches, abrasions, chips, mud, dirt, and dust. Apart from the occasional dented/wrinkled fender, I don't usually put a lot of battle damage on them. Or stowage. Just a thing,
I wonder if there's a class in there somewhere... I can't see much difference in weathering a Sherman vs a Warhammer Baneblade...
INCREDIBLE!!!!!! awesome stuff man! I have a personal project going trying to build a Canadian Kangaroo APC my grand dad was on through the Italian campaign. It was a converted Sherman M4, still have a long way to go (trying to find reference photo's of the interiors is just about impossible)
As I recall, Canada used converted Ram tanks (similar to an early Sherman), Shermans, M7 Priests, and Sextons (similar to a Priest, but with a different gun. They were used as early APCs and gun tractors for towing artillery. Do you know exactly what variant your grandfather had?
The only real thing I have is a photo. The Ram's are for sure the first & foremost versions but I've read when production was halted/couldn't meet demand.....whatever the reason some Sherman's were retrofitted for use. Grand dad passed away before I was born so no chance to ask/clarify things. I'm currently awaiting (the very long wait/time) for his war records to be released to me.
This is a touched up photo my cousin did as the original has several creases/folds, it was carried in his wallet for many years I'm told.
Ok... to the photo. This appears to be an early production M4A1 Sherman cast hull sans turret. It lacks the front visor flaps (mostly used on the earliest production vehicles) on the driver/co-driver hatch housings and carries the early three-piece bolt-on transmission housing. The small shield casting on the nose indicates a vehicle from the Montreal Locomotive Works with hulls sourced from General Steel in Eddystone, PA or Granite City, IL. The hull has the integral .30 machine gun housing, but lacks the gun itself (these are normally retained to provide cover fire for exiting troops). It appears to have the Canadian Dry-Pin steel tracks. Note use of the CDP tracks required the use of a different drive sprocket, What can't be discerned is the use of M3 Lee bogie wheels or the later Sherman bogie wheels and whether the wheels were spoked or solid (stamped). My M10 has the latter with the track skid and trailing arm for the track return roller. The Lee bogies had no skid and the return roller was mounted directly on top of the bogie assembly. There's no shortage of pics of these. FWIW, Sherman wheels, drive sprockets, idler wheels, and bogie assemblies are a study in themselves.
I've never seen any pics (that I can recall) of any variant of a Kangaroo interior. All I know was the turret and all hull ammo racks were removed, 'bench seating' installed, and a metal plate was added between the troop and driver's compartments. I have the impression that the plate completely blocked troop access to the drivers' compartments. I also don't know what, if any changes were made to the turret ring itself (it might be safe to assume the turret gear ring was removed). The crew consisted of a vehicle commander, a driver, and a co-driver/gunner/radio operator. The troop complement consisted of 8-12 troops or as many as they could cram in and on the vehicle. Military expediency and all that...
HTH
Glen
