Hose Adapter for Badger Airbrush?
I just scored me a brand new Badger 105 Patriot airbrush! Problem is...it doesn't fit onto the hose of the Master compressor I have at all. Will this adapter work to help couple it securely to the hose, or will I need to acquire a new hose, or...? I'm keen to get working with this airbrush, but first it needs to fit the hose--help?!
https://spraygunner.com/badger-airbrush-adapter-to-1-8-hose/#topOfPage
  • Replies 4
13 minutes ago, Ratmaster2000 said:
Is your master hose the same connection on both ends? From amazon, it looks like it's an 1/8" connection, so you should be good.. If you are going to have multiple airbrushes eventually, I'd look into some quick disconnects.
I believe it is, yes. I'll go ahead and order that adapter, then, to see what happens. Thanks for the input!
As a heads up, commercial links aren't allowed on the forums here.  You'll want to remove that link.
While I'm not well versed in adapters as all of my gear uses similar ones to Iwata (and then there's quick disconnects), that looks like it would do the job!
