Vesper Project Chapter 3
Auberon
  • Replies 3
11 hours ago, Cygnwulf said:
There are sooooo darned many stl kickstarters these days....
There are tonnes but, as Auberon says, they are much easier to produce than physical minis. So a single sculptor can easily run a STL Kickstarter campaign due to the low barrier to entry. A Kickstarter to produce physical minis has so many more steps involved that you typically need a company to do it.
From a consumer side of things, provided the Kickstarter is showing renders of most of the models, I have confidence that what is being promised will be delivered.
